08-16-2010, 08:21 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 779599 Status: Offline Thanks Meter: 59 | infinity pin finder need help action taken: remove set up and reinstall again no luck. install latest pinfinder set up . but still no luck i doubt why it happen i use my pinfinder the other day its working , but yesterday when i use it . the screen appear like this until now: Initializing... software version: 1.23 Dongle S/N: Dongle firmware version: 0116 Initializing PinFinder... Initializing database... base/user database version: 01/01 Loading configuration... Initializing cable list... Initializing platforms... Initialization finished searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done |
08-16-2010, 09:02 | #2 (permalink) |
Member: 779599 Status: Offline Thanks Meter: 59 | infinity team pls help how could i really know whether my infinity box is ok or my pinfinder is ok cause i try to format the phone with correct pin out but the box dont work , which really the problem my box or the pinfinder |
08-17-2010, 05:32 | #6 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | check rj45 first pin 5v if this volt absent no detect pinfinder. pinout 1---5v+postive 2---rx 3---tx 4---na 5---na 6---na 7---negative 8---negative |
The Following User Says Thank You to Imrankhan For This Useful Post: |
08-17-2010, 05:41 | #7 (permalink) |
Member: 779599 Status: Offline Thanks Meter: 59 | i directly check the box by formating china phone using rj45 cable rx tx without pinfinder but the box dont work even i hold and press the power botton , i try to use the other software the phone run but in infinity box it does not work COM5 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! |
08-17-2010, 05:57 | #8 (permalink) |
Member: 779599 Status: Offline Thanks Meter: 59 | i open finder software i check the cable wire connected to the box of infinity with out connecting to the pinfinder box this is the result pinout 1-----------5v 2-----------rx 5v 3-----------tx 3.8 4-------------na 5------------na 6------------na 7------------negative 8------------negative so now wheres the problem may there is a problem in infinity box cause even i directly conect the phone to the infinity box i doesnt work COM5 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! |
08-17-2010, 19:46 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! if you cant make phone formatted even without pinfinder- this means that this isn't pinfinder problem. you must continue check main infinity box. check if switches is ok etc if still nothing- you need to buy new unibox |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
