06-12-2011, 09:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | @ infinity please have a glance please tell me what do i need to do and what my problem is thank you COM6 [Serial3] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EC03:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... warning: wrong cs at 0x00004FC8, retry... error: too many retries during read operation search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent error: wrong answer: DD error: can't read startup code area #1 rom info detection finished rom info ver: 07 sw version: GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ RD_PCB4_T3ZSP_V02BA_MATRIX.BIN project-id: A19_RD_PCB4_T3ZSP_V02BA_MATRIX, 42A95C9B code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... error: too many retries during read operation error: wrong answer: 5C error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: FF : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... error: wrong answer: 00 . search sec info#1 finished error: wrong answer: 0B error: connection lost Finished, time used: 50 sec Remove/Install battery now ! |
06-13-2011, 09:03 | #5 (permalink) | |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Quote:
i wanted to repair no license to produce problem and i'm unable to read files can you tell me how to convert file which is read by Dragon box to Infinity ? or any other solution to fix following COM5 [Serial2] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EC03:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... warning: wrong cs at 0x000003C8, retry... error: too many retries during read operation search rom info finished searching rom info... error: wrong answer: 00 . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... error: too many retries during read operation error: wrong answer: 5C error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: FF : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... error: wrong answer: 00 . search sec info#1 finished error: wrong answer: 0B error: connection lost Finished, time used: 1 min 8 sec Remove/Install battery now ! | |
06-15-2011, 20:57 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you tried to replace original Comport drivers with drivers available on our support site: software / utilities / Prolific / then i have no more ideas what could be wrong. for doing this you must find in device manager under "ports" prolific device and uninstall it. after system refresh install drivers from our support site. Alternatively you can choose update driver |
06-16-2011, 14:16 | #8 (permalink) |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | @Infinity thank you for replying i have already found and install above drivers still no luck i'll try to find a way to fix it i'll post the result |
