12-14-2008, 12:04 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Kolkata,Kathmandu,
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | Sucessfully Solve T280i Hang problem! COM3 [VCP0] selected module v1.29 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Write: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 203125 Set baud done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20081214-162902.80E.bin Read data done Check data... Check data done Writing... Area: FFS/File system flash: 89890400040089:89890400000000 Write: FFS/File system Writing done Finished, time used: 884 sec Remove/Install battery now ! umadineshdas |
The Following 6 Users Say Thank You to umadineshdas For This Useful Post: |
12-14-2008, 13:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
12-15-2008, 09:27 | #4 (permalink) |
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | I AM SOLVE MY PROBLEM WITH THAT FILE--- T280i_repair_ffs_03.80E. PLEASE TRY THIS FILE WHEN YOU GET THE SAME PROBLEMS? AND INFINITY IS THE BEST FOR THIS TIME TO REPAIR SE-T280i. umadineshdas |
The Following 2 Users Say Thank You to umadineshdas For This Useful Post: |
12-15-2008, 12:09 | #5 (permalink) |
Temporary banned !! Join Date: Mar 2006 Location: Dhaka, Bangladesh Age: 37
Member: 243500 Status: Offline Sonork: 100.1590322 Thanks Meter: 584 | OM10 [VCP0] selected module v1.30 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Write: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 11 sec Remove/Install battery now ! what is the problem i have tryed with hold power button |
12-15-2008, 12:21 | #6 (permalink) |
Member: 243500 Status: Offline Sonork: 100.1590322 Thanks Meter: 584 | problem solved by restarting pc thanx infinity |
The Following User Says Thank You to sajib_ngage For This Useful Post: |
12-15-2009, 15:49 | #8 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | t280i hang at "sonyEricsson" problem solved by eeprom repair file ... COM8 [VCP0] selected module v1.37 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active skip: Firmware skip: Flex/Customization skip: Language Pack skip: FFS/File system skip: Images skip: Melody write: Eeprom T280i_repair_ffs_03.80E.bin Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: E:\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20091216-074211.80E.bin Read data done Check data ... Check data done Write ... Area: Eeprom flash: 89890400040089:89890400000000 Write: Eeprom Write done Finished, time used: 335 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to zeerik For This Useful Post: |
12-16-2009, 08:25 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work Br Faisal_Computer |
06-15-2010, 10:12 | #10 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Jainagar Bihar
Member: 992600 Status: Offline Thanks Meter: 1,670 | Quote:
plz share t280i flash file and eprom file thanx | |
Sony Ericsson T280i hanging on sony ericsson logo solution here | VIJEESHNK | Infinity-Box | 17 | 01-04-2014 09:25 |
SONY ERICSON T280i HANGING | imran_4_u | Sony Ericsson Hardware Repair | 1 | 12-19-2009 10:59 |
Sony Ericson T280i Hang with logo | Unicom | Infinity-Box | 2 | 09-01-2009 14:31 |
Solve the hang problem of 5130 for the first time | mamal_ghan | Nokia Hardware & Hardware Repair | 5 | 08-17-2009 23:52 |
Newbie need help solving N70 white screen hang problem | Nadim0n | Nokia Hardware & Hardware Repair | 4 | 07-24-2007 20:06 |
