Infinity Please HELP I unlock vodafone 340, now phone is dead,I dont know why there is no error in unlocking Log here, ==== [2/5/2012 5:27:18 PM] ==== COM67 [VCP0] selected module v4.13 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6703:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BIN project-id: BM35A1.V2.22.M00.02.42, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... ....................................... lock area found ....................................... lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: lock-area-1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__system_log__00000000_20120205-172906.B0X.bin Finished, time used: 1 min 45 sec Remove/Install battery now ! Infinity please help, what am going to do? i try to download flashfile to support but it says my support is expired. please help, please share flashfile i cant afford for now to activate my support.. thanks in advance to all. |
calling attention of infinity team, what should i do to revived this phone???? |
hello! log looks perfectly OK. are you sure that your phone's battery is not near to death? also, do you hold power button pressed long enough? |
i charge the battery from desktop charger, please help me i need to revive the phone before saturday. |
Successfully Revived Quote:
heres log: flashing process [Infinity Box] MModule v4.13 smart-card: connected S/N: 441B:xxxx Wait... Device: _Autodetect MT6205-6239 NOR Initialization done Device: Vodafone-340 Loading file v.05... Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_23_M 00_02_35.BIN project-id: BM35A1.V2.23.M00.02.35, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: [standard] type (05) TCL-ID is absent firmware date/time: 2009-10-23 22-03 hw1: FOXLINK25_08B_HW hw2: 08B_FOXLINK25_08B ==== [2/10/2012 2:38:07 PM] ==== COM67 [VCP0] selected module v4.13 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 3 sec Remove/Install battery now ! ==== [2/10/2012 2:39:05 PM] ==== COM67 [VCP0] selected module v4.13 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 6 sec Remove/Install battery now ! ==== [2/10/2012 2:39:23 PM] ==== COM67 [VCP0] selected module v4.13 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6703:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_23_M 00_02_35.BIN project-id: BM35A1.V2.23.M00.02.35, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35__system_log__00000000_20120210-144034.B0X.bin Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization detected: BM35A1X1 customization: BM35A1X1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35__system_log__00000000_20120210-144233.B0X.bin Finished, time used: 3 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Unlocking Process COM67 [VCP0] selected module v4.13 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6703:A009 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.23.M00.02.35 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203304167 connection Ok 186 byte(s) read reading data... warning: wrong packet cs reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
expired box.............................. |
