10-14-2018, 20:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: World Wide Age: 54
Member: 120932 Status: Offline Thanks Meter: 58 | KYOCERA Hydro VIEW C6742 UNLOCK is IMPOSSIBLE? I have asked and practically begged to almost all dongles or boxes developers, but nobody pays attention to me, maybe you who have many years in the market can give me a solution with this problem. This model of Kyocera C6742 really can be unlocked, but there is the problem with the diagnostic port, because once unlocked it loses the IMEI and does not allow to rewrite the IMEI, I am willing to send a blocked Kyocera C6742, Please require your attention, thanks in advance and a hug. -- Checking Current Version -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : KYOCERA-C6742 -- MANUFUCTURER : kyocera -- ANDROID VERSION : 5.1.1 -- CPU : armeabi-v7a -- MMC STORAGE : 0 Bytes -- HARDWARE : qcom -- BOARD : C6742 -- BOOTLODER : unknown -- USB CONFIG : charge_only,modem,adb -- USER : release -- BASEBAND : 4-00034-M8909EAAAANVZM-1.28092.1 -- DISPLAY ID : LMY47V -- BUILD ID : LMY47V -- REGION : US -- LANGUAGE : en -- SIM STAT. : ABSENT -- BUILD DATE : Tue Nov 17 23:04:20 JST 2015 -- BUILD TAGS : release-keys -- NETWORK TYPE : Unknown -- SIM OPERATOR : -- LCD DENSITY : 240 -- IMEI 1 : -- IMEI 2 : service: iphonesubinfo2 -- ROOT STATUS -- Superuser.Apk : Not Installed -- BusyBox : Installed -- BusyBox Version : 1.13.3 -- Su Binararies : kingo 14 -- Root Status : ROOTED |
10-14-2018, 21:02 | #2 (permalink) |
Member: 120932 Status: Offline Thanks Meter: 58 | 2018-01-09 - 15:23:30 : 2018-01-09 - 15:23:30 : IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! 2018-01-09 - 15:23:30 : Waiting For Device... OK[WinUSB] 2018-01-09 - 15:23:31 : Device Status: [ONLINE] 2018-01-09 - 15:23:32 : Model : KYOCERA-C6742 2018-01-09 - 15:23:32 : Manufacturer : kyocera 2018-01-09 - 15:23:32 : Serial No. : 68d20425f1 2018-01-09 - 15:23:32 : Baseband : msm 2018-01-09 - 15:23:32 : BaseBand Version : 4-00034-M8909EAAAANVZM-1.28092.1 2018-01-09 - 15:23:33 : SW Version : 1117_2301 2018-01-09 - 15:23:33 : Custom Version : 2018-01-09 - 15:23:33 : Android Version : 5.1.1 [LMY47V ] 2018-01-09 - 15:23:33 : Built Date : Tue Nov 17 23:04:20 JST 2015 2018-01-09 - 15:23:33 : Fingerprint : kyocera/C6742/C6742:5.1.1/LMY47V/1117_2301:user/release-keys 2018-01-09 - 15:23:44 : Checking Root Permission... OK 2018-01-09 - 15:24:26 : Prepairing Security... OK..OK..OK..OK 2018-01-09 - 15:25:02 : -----> Backup Security(1)... OK..OK..OK 2018-01-09 - 15:25:38 : -----> Backup Security(2)... OK..OK..OK 2018-01-09 - 15:27:23 : -----> Backup Security(3)... OK..OK..OK 2018-01-09 - 15:27:24 : SECURITY AREA Files Saved in : 2018-01-09 - 15:27:24 : C:\AHT2\BACKUP\SECURITY\KYOCERA-C6742\2018_09_01__15_23_54\SEC_KYOCERA-C6742.zip 2018-01-09 - 15:27:56 : Unlocking... OK..OK..OK 2018-01-09 - 15:27:56 : Rebooting to Normal Mode... OK 2018-01-09 - 15:27:56 : The phone is unlocked, but it remains without IMEI, please you who are the experts in the subject, I know that if you can unlock this cell |
10-14-2018, 21:17 | #5 (permalink) | |
Member: 120932 Status: Offline Thanks Meter: 58 | Quote:
with the AA_v3 software the developer of Furious try to make backup of the EFS zone with this software Revskills, but I do not achieve it via remote Last edited by Cell-Manager; 10-14-2018 at 21:24. | |
10-16-2018, 00:31 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,786 | Quote:
- DO you know that using usb remote sharing software with infinity may permanently block your dongle ? - Did you notice that this is INFINITY BOX support section, not other boxes ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 4 Users Say Thank You to Brka For This Useful Post: |
10-16-2018, 06:36 | #7 (permalink) | |
Maybe if I sent you a Kyocera C6742 you can add it to your prestigious dongle. | |
10-16-2018, 10:09 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | There is no reason to send device before you will try to connect it with currently released software. Also even if you will send a phone thre is absolutely no guarantee that this device will be supported. So my advice - try to connect phone with CM2QLM software first and see result. After you will be able to post operation log text it will be an information for programmers for future research. |
10-16-2018, 18:06 | #9 (permalink) | |
10-23-2018, 19:28 | #10 (permalink) | |
Freak Poster Join Date: Feb 2012
Member: 1725927 Status: Offline Thanks Meter: 24 | Quote:
I have infinity box but is not actived, can help me to activated this box please?, have kyocera c6742 in handsm can tested if is done but firts need activate my box | |
The Following User Says Thank You to yankee02 For This Useful Post: |
