03-12-2009, 11:18 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: inside nokia tuning plant Age: 48
Member: 48980 Status: Offline Thanks Meter: 7 | to infinity support when i read detailed info it looks like this..... COM14 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:2203:000F boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:82435100000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:82435100000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:82435100000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:82435100000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 82895143EA69891880698900081828606869A968201A4843 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:82435100000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00FF0000 Detected eeprom/ffs address is non-standard: 00FF0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00FF0000 detecting eeprom/ffs size... eeprom/ffs size: 00010000 ffs chip: 00 eeprom/ffs area: 00000000:00FF0000-00FFFFFF detecting ffs structure pass 1... .................................................. .............. can't detect fat record name location error: ffs detection failed: element #1 detecting ffs structure pass 2... .................................................. .............. can't detect fat record name location error: ffs detection failed element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 82 sec Remove/Install battery NOW WHAT FIRMWARE FILE I NEED TO FLASH AND WHEN I READ FULL FLASH IT SAVES THIS FILE flash_20090312-170252.B0M AND EEPROM eeprom_20090312-170815.B0E |
03-13-2009, 04:39 | #3 (permalink) |
Member: 48980 Status: Offline Thanks Meter: 7 | k thanks....how can i know firmware version or close to it, my pcb has ic MT6225A 0839-ABTLKTF0C246 & SAMSUNG IC 825 AND A STICKER ON BOARD WITH PRINT K300_JX_MTK_V1.01.25.SM |
03-14-2009, 22:25 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! probably K300_JX is part of firmware name, but search for this returns zero result try different 6300 firmwares from support, this is only what i can suggest |
to infinity support , pls we need alcatel 203ex simfree file in support | segun4u | Infinity-Box | 21 | 11-22-2009 14:33 |
how to send file to infinity supporter | jignesh269 | Infinity-Box | 1 | 03-06-2008 19:28 |
to infinity support | doudiunlocker | Infinity-Box | 4 | 12-07-2006 21:43 |
to infinity support | REALTHOMAS | Infinity-Box | 7 | 06-07-2006 08:20 |
to infinity support | vascof1 | Infinity-Box | 2 | 06-15-2005 08:33 |
