12-11-2007, 15:32 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | mobile on/0ff |
12-11-2007, 18:20 | #3 (permalink) |
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | i have proper pinouts but mobile dont have model nmber on back on imei and casing which file i write here is detail Device: Autodetect 6228 NAND Checking data, wait... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud... 460800 Set baud Done Identification... reading... detecting structure... converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: Y310_PCB04_GPRS_MT6228_S02.Y310V10_06_52_V1_6T09D0 70426.BIN ver. sw2: Y310V10.06.52.V1.6T09D070426 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation Finished, time used: 44 sec Remove/Install battery now ! format ffs safe not done bcz mobile not on properly mobile on and off without sim what can i do plz help |
12-11-2007, 18:44 | #4 (permalink) |
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | here is the firmware back up link http://rapidshare.com/files/75872778...-194642.B.html when itry format ffs complete done Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud... 460800 Set baud Done Identification... reading... detecting structure... converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: Y310_PCB04_GPRS_MT6228_S02.Y310V10_06_52_V1_6T09D0 70426.BIN ver. sw2: Y310V10.06.52.V1.6T09D070426 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done Finished, time used: 46 sec Remove/Install battery now ! but problem not solved |
12-12-2007, 14:45 | #9 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | be Patient man .. they will be there ...... after 3-4 hours ........... definately they wil have somethign to say about this Mt6228 Chip type |
12-12-2007, 16:25 | #12 (permalink) |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | bro u must use baud rate to 115200 as this is the recommended baud rate by infinity Support for Mt6228 with this problems so try it .. and good Luck |
k800 flashing error...... mobile on white display and off then on off | >>.123.<< | SETool2 | 1 | 03-05-2010 09:01 |
Urgent on 0ff track 6600 | dev452005 | Nokia Hardware & Hardware Repair | 3 | 12-27-2008 16:25 |
nktel sim inside mobile off with out sim mobile on | jagadeesh22 | Chinese Models & Cloned Phones | 3 | 08-18-2008 07:41 |
