12-18-2008, 17:03 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Infinity Support need Short Answer After use Pin Finder results are: software version: 1.16 cable type: 2x6 (L12B) platform: MT: MT62xx (autodetect) searching adapter at COM4... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6205 result: Rx:4 Tx:2 time required: 21 sec Power On ! So wich module too use for Formating Device CPU: MT6205 Regards |
12-18-2008, 18:04 | #3 (permalink) | |
For MT6205...MT6230 you need to use ChineseMiracle module. Infinity-Box cables based on this pinout numbering mode: 1 2 3 4 5 6 7 8 9 10 | |
12-18-2008, 19:05 | #5 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 940 | Ok pinout found but COM4 [VCP2] selected module v2.71 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6205:8B00]... CPU: MT6205 high speed boot On Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 99 sec Remove/Install battery now ! BoundRate AutoSelcet Button Long time pressed Phone Probelem is restarting Reagrds |
12-18-2008, 19:19 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, In case of seriously damaged eeprom it is need to use "complete" format instead of "safe". Make full flash backup before this operation ! |
12-18-2008, 19:27 | #7 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 940 | Now m facing with other problem Dongle Damaged i try update after i get this prob but get ----------Process started: 19:24:31---------- Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: xxxxxxxx, Firmware: 0112.01 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs: Dongle is up-to-date and has latest firmware. Don't try more ! If software can not start (or SmartCard data is damaged) contact to [email protected] Regards |
12-18-2008, 19:44 | #10 (permalink) | |
12-19-2008, 10:22 | #11 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
How to solve this problem What is Dongle Damaged data error code 65 ????????? Regards Last edited by Formingus; 12-19-2008 at 10:23. Reason: ok | |
Supporters and Resaillers need short answer hear thks :) | Formingus | Z3X-Team Products | 12 | 10-14-2009 13:24 |
Why silent infinity supporter??? Need help plz | GSMHEART | Infinity-Box | 3 | 06-03-2009 11:10 |
@Infinity-Supporter! Need Info! | [Shadab_M] | Infinity-Box | 1 | 02-28-2009 20:21 |
infinity support need help plz | mena_ishak | Infinity-Box | 5 | 04-11-2008 16:57 |
@ Infinity Support !! need salution for VK200 flash | Faisal_Computer | Infinity-Box | 2 | 04-19-2007 13:13 |
