11-14-2009, 03:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: INNER SIDE OF MOBILE PHONES
Member: 369802 Status: Offline Thanks Meter: 82 | to infinity support , pls we need alcatel 203ex simfree file in support |
11-16-2009, 22:39 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is direct unlock solution for Alcatel models. It's beta solution, need to test it and see what will be the results. Please, try to unlock phone with this new software: http://www.infinity-box.com/download...dule_v2.94.rar It is no need to flash phone, just use "SP-Unlock" button from software "Service" page. Waiting for your results. |
11-16-2009, 23:50 | #3 (permalink) | |
No Life Poster Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | Quote:
Any idea how to revive? COM4 [VCP0] selected module v2.94 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:742D:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203EX-2BRGGB1 customization: CM37CS32 customization: XM37CS32 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... customization: XM37CS32 done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091116-224643.B0X.bin Finished, time used: 72 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
The Following User Says Thank You to Seedy For This Useful Post: |
11-16-2009, 23:57 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. send C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091116-224643.B0X.bin to [email protected] 2. read full flash backup and send full flash backup file to [email protected] 3. check battery voltage 4. try to press and hold phone "Power" button for a long time 5. if still no luck, try to make "repair security area" 6. if still no luck, try to flash phone with any firmware from support area |
11-17-2009, 00:02 | #5 (permalink) |
Member: 8102 Status: Offline Thanks Meter: 118 | Hi 1 & 3 will be done in a few minutes 3 - its full 4 - already tried 5 - already tried (I am sorry but the backup will contain this - while doing this i did get an error about security error part 2 so will use existing) 6 - will let you know later if okay after flash |
11-17-2009, 00:11 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, "system_log" file received and required data extracted. If you will be need to restore phone to it's original state we will be able to do so after we will get full flash backup from phone in it's current state. Also we will try to double check unlock process. I am very sorry for troubles ! |
11-17-2009, 00:23 | #7 (permalink) |
Member: 8102 Status: Offline Thanks Meter: 118 | okay two things First flashed with the 203EX flashfle and now working but locked to Virgin Secondly have you got an Orange UK Flash file so at least I can restore phone? Thirdly anyway of unlocking this at the moment? Thanks Last edited by Seedy; 11-17-2009 at 00:31. |
11-17-2009, 05:45 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I did not received full flash backup from you yet, please, send it anyway. You can try to unlock phone again now. Updated software can be downloaded by the old link. Please, keep me informed about results. |
11-17-2009, 15:02 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use latest software for unlock: http://www.infinity-box.com/download...e_v2.94_v2.rar |
11-17-2009, 19:29 | #11 (permalink) |
Member: 8102 Status: Offline Thanks Meter: 118 | Finally success - one click unlock One thing though is it possible you can upload Orange UK flash for 203ex? COM4 [VCP0] selected module v2.94 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:742D:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37D provider: 203EX-2AVRGB1 customization: CM37CN35 customization: XM37CN35 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... customization: XM37CN35 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091117-182653.B0X.bin Finished, time used: 76 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 4 Users Say Thank You to Seedy For This Useful Post: |
11-18-2009, 10:09 | #13 (permalink) | |
Member: 369802 Status: Offline Thanks Meter: 82 | Quote:
thanks alot infinitysupport, pls upload to support 4 others to benefit | |
11-18-2009, 11:54 | #14 (permalink) | |
We want to get test reports and probably fix some possible problems with some models before we upload this software for all users in support area. It may be that we will need to make some software modifications for some models. | |
11-18-2009, 20:26 | #15 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Colombia
Member: 193303 Status: Offline Sonork: 100.1613585 Thanks Meter: 104 | Good solution for OT600A. COM7 [VCP0] selected module v2.94 Device: Alcatel-600 Checking data, wait... advanced flash detection enabled Action: rebuild security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:0203:A00A status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.91 B03FAE.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 91B03FAE rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 address offset: 00020000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2EVRGB1 customization: CJ26NG12 customization: XJ26NG12 TCL-ID identification done ffs address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... customization: XJ26NG12 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... customization: XJ26NG12 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 00000000000000 flash: 98000300000001:08EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_91B03FAE_C4B7397C_20091118-142316.B0X.bin Finished, time used: 218 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! But i can't change imei to this model, any solution?? The Infinity team is the best!!! Br |
The Following User Says Thank You to geriaf For This Useful Post: |
Alcatel 203x simfree file not on support | francogsm | Infinity-Box | 10 | 03-11-2010 22:16 |
Alcatel Ot363 won't power on with simfree flash in support | abdoune | Infinity-Box | 39 | 11-18-2009 17:15 |
I need alcatel S319a simfree fullflash | supercell | Infinity-Box | 0 | 06-06-2009 22:41 |
Dear Infinity-Team Where Is O2 X3 Model Flash File In Support Area Pls Help | uttam | Infinity-Box | 4 | 01-06-2009 16:24 |
Need Sx1 Intel Flash File in support | ssatcom | SST-Dongle | 1 | 08-12-2005 22:08 |
