11-29-2010, 14:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | 1112 Still "Bad Software"... COM3 [VCP0] selected module v3.25 Action: repair "Bad software" Step 1 of 2 is complete ! Press "Ok" now and then make step 2 ! If phone did not connect: remove/install battery. Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot On chip: 0011:7C2C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! |
11-29-2010, 15:17 | #2 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | Full flashed with these files (download from support ) but still on bad software. 1. TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53_Nokia-1112_8m_En_Fr_Es_Pt_De_Ml_Vn_Tr_Ru_Ar_Urdu_Th.B0M 2. TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53_8m_En_ Ru_Fr_Th_Vn_Urdu_Farsi_Ar.B0M |
11-29-2010, 15:21 | #3 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | Here is detailed information.... COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot On chip: 0011:7C2C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53.BIN project-id: N1112_V5.53, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00700000 standard ffs/eeprom offset confirmed: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF firmware area: 00000000-006FFFFF detecting ffs/eeprom structure pass 1... .............. ffs/eeprom: detect std location pass #1... ............................ ffs/eeprom: detect ext location pass #1... ........................ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53.BIN detecting firmware build... ........................ firmware date/time: 2008-05-30 18-31 hw1: N1112_V5.53 hw2: RH-93_TOP23_07A done detecting product-id... ................................ done detecting languages... ................... language parameters detected detected languages: En Ru Fr Th Vn Urdu Farsi Ar Finished, time used: 1 min 3 sec Remove/Install battery now ! |
11-29-2010, 15:33 | #4 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | After Full Flash repair Bad Software log is here...but still on "Bad Software". COM3 [VCP0] selected module v3.25 Action: repair "Bad software" Step 1 of 2 is complete ! Press "Ok" now and then make step 2 ! If phone did not connect: remove/install battery. Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot On chip: 0011:7C2C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! |
11-30-2010, 05:53 | #7 (permalink) | |
Member: 751908 Status: Offline Thanks Meter: 186 | Quote:
After all operations still bad software. I think there is no solution for this. COM3 [VCP0] selected module v3.25 Action: repair "Bad software" Step 1 of 2 is complete ! Press "Ok" now and then make step 2 ! If phone did not connect: remove/install battery. Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot On chip: 0011:7C2C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! | |
Nokia link still down?!?! | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-15-2001 13:08 |
5110 v5.29 STILL LOCKED... | cris | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-14-2000 19:02 |
Still with nokia 5110 ver 5.24 | VirtualM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-11-1999 18:57 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
