Old 06-07-2016, 15:19   #1 (permalink)
Member: 1984825
Thanks Meter: 222
please team i want you help me
Scatter Load Ok , BaseBand : MT6582 , Project : wiko , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.48 ]
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1616.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A324EB61E5
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A324EB61E5
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xC3A2D657D77F43508E5359358EA8A8A6
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : wiko , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3535 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000BF000000
Flash Pre-Erase Done, time used : 00:00:28
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wiko.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:01:08
Reconnect Power/Cable!
======= Flash
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Setting : AFF verify : Disabled
Setting : HW verify : Disabled
BL : Skip checking by User request!
BL : BatteryLevel : 3536 mV
Flash Pre-Erase Done, time used : 00:00:22
Operation Failed
Elapsed: 00:00:43
======= Flash
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
BL : BatteryLevel : Unknown (not supported or without battery)
Operation Failed
Elapsed: 00:00:53
Old 06-07-2016, 15:52   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
First charge battery and make HW Test.
If HW test is passed erase flash first and then flash phone.
Br.
Infinity Box Support Team.
Old 06-08-2016, 15:08   #3 (permalink)
Member: 1984825
Thanks Meter: 222
Operation : HW Test [ v1.48 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
SOC VERIFY : C1
Boot Ok!
Initial info read error! Erased or damaged FlashIC?!
Operation Failed
Elapsed: 00:00:12
Old 06-08-2016, 15:25   #4 (permalink)
Member: 2029910
Thanks Meter: 4
untick battery check
Old 06-08-2016, 15:31   #5 (permalink)
Member: 1984825
Thanks Meter: 222
please explain where can i find this option (battery check )
thank you bro
Old 06-09-2016, 17:02   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
eMMC is ReadOnly.
If you made flash erase and got same result after - time to change it.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.37315 seconds with 8 queries
