02-13-2010, 19:35 | #1 (permalink) |
Banned Join Date: Feb 2008
Member: 715429 Status: Offline Thanks Meter: 258 | @ infinity team . Big Update new 6 zte models. read and add models ready ((read)) hi infinity team please add this models zte a316i zte s315 zte s315+ zte s316+ zong f321 zong f323+ log de operaciones... operation LOGS select zte a316 in pana module zte a316i zte s315 zte s315+ zte s316+ COM5 [VCP0] selected module v1.68 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: CEL-P108A27FM U V1.0.0B03 Sep 15 2009 15 57 13 COMCEL-P108A27FM Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20100204-142011.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20100204-142012.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20100204-142013.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20100204-142016.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 27 sec Remove/Install battery now ! all operation inproved repair imei ffs format unlock repair eeprom all sucsefully and tested by residentdenuevo select huawey t710 zong f321 zong f323+ Action: "sp-unlock" unlock method: smart fast Model: Huawei-T710 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9C9F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: T710CA.P10.M21.01.14 Version: HUAQIN23_08A_HW 80 byte(s) read imei: 00000000000000000000000 connection Ok 186 byte(s) read reading data... reading data #4... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 22 sec Remove/Install battery now ! pinout avaible in date base.. FILES AGAIN AND WERE SENT TO SUPPORT Crush competition. THE POLAR BAG FOR TEST TODAY .. INFINITY AND SUPPORTED YOU HAVE IT READY FOR OPERATION WITH ALL ... PANA UPDATE MODULE -- WAITING |
The Following 28 Users Say Thank You to residentdenuevo For This Useful Post: |
02-13-2010, 19:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: nederland
Member: 523332 Status: Offline Thanks Meter: 273 | thanks for the repport and the good info. infinity are a big and good team, we must always support them. they give the best for less money. thanks infinity team |
02-13-2010, 19:45 | #3 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,988 | @residentdenuevo Thanks a lot, it's really good info ! pls, if you still have phones on hands, read full flash from all of them and send files to [email protected] Thanks a lot ! |
02-13-2010, 20:01 | #5 (permalink) |
Member: 715429 Status: Offline Thanks Meter: 258 | thanks to jesedavidfrv for phote of models zte ... gracias por las fotos jesedavidfrv -- es que no conseguia fotos del modelo y encontre las suyas mi portatil esta sin driver de cam.. jejeje gracias-- |
02-14-2010, 00:02 | #7 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Yeahhhhh..... I add and send the full flash of ZTE S315+ read of ZTE A136 to infinity support, but the support model not add..... It's time to add this models to support...... We work for the GSMcommunity....RESIDENTGSM, MAOMATRIX, EDUARDODULCEY, MOVILCELULARES, ALFREDOVALE9.. AND OTHERS. We are The Portalnova TEAM.!!!!!!!! |
The Following User Says Thank You to maomatrix For This Useful Post: |
02-15-2010, 15:21 | #10 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,988 | Hi, We did not got zong f321 and zong f323+files yet. Please, send it onceagain to [email protected] And the same with zte a316i, zte s315, zte s315+, zte s316+files, do not received it yet too. We can not make any update w/o flash files due to we must check everything very very very carefully to avoid damaged phones. please, send files to [email protected] Thank you ! |
02-15-2010, 15:24 | #11 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,988 | Also what is exact pinout for each model ? I can see exact pinout for ZRE-S315 only, but what is pinout for S316 and for F321 and for F323 ? |
02-15-2010, 15:29 | #12 (permalink) | |
Member: 1043909 Status: Online Thanks Meter: 60,988 | Quote:
What pinout you have used for S315+ ? Is it the same model as S315 ? | |
