01-11-2011, 22:37 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 417512 Status: Offline Thanks Meter: 46 | HELP to unlock coral 280 Read backup with model: bleu 255, I try to flash the phone with firmware of coral 255 and 550 and phone become dead, then flash the backup and live again. Phone Details: Marca: Coral Model: 280 Text from back label: Model: c280/9 FCC ID: T38PCD1032 Band: 900/1800 Pinout: (same as coral 620, 640, 655, utstarcom 1238, 1328, etc) Cable name: SFR-341 connector 2x5 (L10C) /1 2 3 4 5\ |6 7 8 9 10| 4: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) 5: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) 6: Gnd (RJ45 pin-8) Here is the backup: (full flash, firmware and Eeprom) http://rapidshare.com/files/442051694/280.rar Here is log: Code: ==== [11/01/2011 02:20:20 p.m.] ==== COM3 [VCP0] selected module v3.72 Device: Bleu-255x Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4C0C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\id.47201FCF.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN_8D6F0469].rpl ==================== New firmware found (v.3.72, database date: 23.12.2010): CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 47201FCF rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN project-id: C1032_2.2_0x11106_EU_DIGICEL_SAMSUNG_P1, 69046F8D code offset: 00000000 ffs offset/size [02]: 00700000/00100000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__ffs... file saved: C:\Celulares\Infinity BOX\Firmware\Coral\280\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__ffs_20110111-142436.B0E.bin file saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__system_log_47201FCF_8D6F0469_20110111-142546.B0X.bin Finished, time used: 5 min 5 sec Remove/Install battery now ! ==== [11/01/2011 02:25:48 p.m.] ==== COM3 [VCP0] selected module v3.72 Device: Bleu-255x Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4C0C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\id.47201FCF.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN_8D6F0469].rpl ==================== New firmware found (v.3.72, database date: 23.12.2010): CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 47201FCF rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN project-id: C1032_2.2_0x11106_EU_DIGICEL_SAMSUNG_P1, 69046F8D code offset: 00000000 ffs offset/size [02]: 00700000/00100000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__fullflash_part_1_of_1... file saved: C:\Celulares\Infinity BOX\Firmware\Coral\280\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__fullflash_part_1_of_1_20110111-143412.B0M.bin file saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__system_log_47201FCF_8D6F0469_20110111-143442.B0X.bin Finished, time used: 8 min 49 sec Remove/Install battery now ! ==== [11/01/2011 02:34:45 p.m.] ==== COM3 [VCP0] selected module v3.72 Device: Bleu-255x Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4C0C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\id.47201FCF.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN_8D6F0469].rpl ==================== New firmware found (v.3.72, database date: 23.12.2010): CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 47201FCF rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN project-id: C1032_2.2_0x11106_EU_DIGICEL_SAMSUNG_P1, 69046F8D code offset: 00000000 ffs offset/size [02]: 00700000/00100000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__firmware_part_1_of_1... file saved: C:\Celulares\Infinity BOX\Firmware\Coral\280\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__firmware_part_1_of_1_20110111-144046.B0M.bin error: can not make firmware backup file saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__system_log_47201FCF_8D6F0469_20110111-144118.B0X.bin Finished, time used: 6 min 28 sec Remove/Install battery now ! Loading file v.02... coral255-255x_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.SFE-DIG9-P109A14V1_0_0B04__ffs_20100807-001127.B0E.bin loaded If you need something else let me know Thanks |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
