Infinity Team Help Me Please.. I have Many Bin Files but i want to make In scatter files .i know MTK Droid Tool Convert the bin file to scatter file but Need to connect the mobile In USB Dub Mode.Now i have a many models bin file No mobile in hand. i hop Team and My friends Understand My Question. Thanks in advance Regards .::Mustafa::. |
Hello, Infinity-Box CM/CM2 already supports .bin file format, so there shouldn't be any problem in using it. About conversion it's not possible for now. Br. Infinity Box Support Team. |
Yes, is good for someone to understand this very well |
Nand is not issue face with multi chips |
Also if possible with phone details and logs. Br. Infinity Box Support Team. |
1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xC3555188BF151143E96970694DE6461C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! http://i288.photobucket.com/albums/l...g?t=1481374801 Please add bin to file converter in Great Tool CM2 Regards .::Mustafa::. |
it's Nand chip NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xC3555188BF151143E96970694DE6461C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! |
its nand chip bro you should found flash file for your phone.search net |
