Infinity Team help me urgent I have a Zong (ZTE) A136 in hang fault.....after flash, now it is restarting after sim insert.....please guide me how to solve it....Thanks Here is the flash log.... COM3 [VCP0] selected module v1.78 Device: Zong-A136 Checking data, wait... Action: write flash write: Firmware ZTE-A136_main_CMPAK-P108A2B07-En-PK01_g3dBV2.0_Apr-24-2008.B1M.bin skip: FFS-1/Customization write: Language Pack ZTE-A136_lp_CMPAK-P108A2B07-En-PK01_g3dBV2.0_Apr-24-2008.B1P.bin skip: Graphics Pack skip: FFS-2/File system write: Eeprom Zong-A136_eeprom-complete_01.B1E.bin Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20110224-171714.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20110224-171715.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20110224-171722.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 7 min 40 sec Remove/Install battery now ! |
Hi, Did you tried to make 112/emergency call without sim card ? What is the results ? |
do you have original full flash backup ? did you tried to restore original eeprom backup ? What is the results ? |
software make backup automatically: file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20110224-171714.B1E.bin file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20110224-171722.B1E.bin firmware in your phone was exactly the same as exist in support area. |
hmm.....Now what is the solution...if u have? |
solution: try to flash phone with your own eeprom_complete file if phone still can not make 112 call - open phone and clean water or rehot/reball cpu or check any other HW damage. |
