01-21-2016, 09:29 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote: no any plan to add cpb format flash if you will use your little brain , sure you will be no need to add this select file in ygdp tool after select go to (C:\YLXZGJ\YGDP) you will see new folder match with time n date copy these file or any drive then close ygdp tool - now open cm2 and select scatter file and flash ur phone by cm2 | |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
