Old 07-28-2009, 10:44   #1 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 199
Sigmatel s88 not calibrated solution
Hi flash thish eeprom file for s88 not calibrated problem
The Following 4 Users Say Thank You to tajinder For This Useful Post:
Old 07-28-2009, 10:46   #2 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
thankss but you can do this job with infinity to click calibrat tach so check it bro.
Old 07-29-2009, 22:31   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
How to calibrate touchscreen (if toucscreen panel is damaged):
1. connect cable from box to phone
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model
6. go to software "Settings" page and select COM port
7. make full flash backup for emergency case
8. go to software "Service" page
9. select calibration "mode-1"
10. make "Reverse calibration order" un-checked
11. press "Calibrate touchscrren" button and follow instruction given by software
12. if software can not make calibration with "detection failed" error:
- select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one)
- repeat calibration process
- test phone after each "mode" try
13. if calibration process finished without errors but touchscreen can not work well:
- DO NOT change calibration "mode" !
- make "Reverse calibration order" option checked
- repeat calibration process again
- test phone
14. if still no luck with calibration after all tries:
- make full flash backup for emergency case
- make "format ffs"
- Power-On phone
- Power-Off phone by "Power" button (do NOT remove battery)
- Repeat "Calibration" operation again
- if still no luck read full flash and send to support with subject: touchscreen calibration failed
Old 08-06-2009, 23:25   #4 (permalink)
Member: 130995
Hello,
Touchscreen calibration procedure changed, ChineseMiracle v2.88 released: http://forum.gsmhosting.com/vbb/showthread.php?t=801258
Please, try to calibrate phone with new software, waiting for your results.
Old 08-07-2009, 08:56   #5 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
Yes Try with latest update as i did n got success logs posted in forum with new procedure LONG_LIVE INFINITY,,
The Following User Says Thank You to mobile_hotman For This Useful Post:
Old 08-09-2009, 16:54   #6 (permalink)
Member: 214340
Thanks Meter: 906
ANOTHER_TOUCH_SCREEN_CALIBRATION_DONE_WITH_NEW_UPD ATE
LOGS
COM12 [VCP0] selected
module v2.87
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
M200DS_PCBV1_1_GPRS_MT6226_S01.M200DS_CE_127N_O70_ BT_V04__fullflash_20090809-083643.B0M.bin loaded
detected record size adjusted
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:803E:E551
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: M200DS_CE_127N_O70_BT_V04
Version: FYD26_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
204 byte(s) read
reading data #2...
writing data...
verification...
verification Ok
Finished, time used: 14 sec
Remove/Install battery now !
LONG_LIVE_INFINITY
The Following 2 Users Say Thank You to mobile_hotman For This Useful Post:
Old 10-05-2009, 07:48   #7 (permalink)
Member: 360614
Thanks Meter: 63
Any possible idea with spiderman, cause I don't have infinity. Or can u give me a link of flash file of sigmatel S98
MTK_ROMINFO_v04T600_V05_PCB01_GPRS_MT6226_S01.T600 _V05_ENFRARRUSPPEVI_SIGMATEL.BIN
Old 06-26-2010, 12:25   #8 (permalink)
Member: 867442
Sonork: 100.1602740
Thanks Meter: 143
it not solve my problem
Old 06-27-2010, 21:02   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what is your phone original software version?
also please post log of Calibration-Auto mode
sigmatel S88 shows NOT CALIBRATED k_abhi Infinity-Box 27 12-13-2011 11:17
China Sigmatel S88 when swithc on says " Not calibrated" mukeshdurg Chinese Models & Cloned Phones 14 11-10-2010 01:30
Frome F8 Not Calibrate solution babloojaved Infinity-Box 0 02-08-2010 11:45
china s88 shows - NOT CALIBRATED k_abhi SpiderMan 1 01-01-2010 14:44
sigmatel s88 shows only not calibrate rakesh15 Infinity-Box 0 06-11-2009 06:51
Page generated in 0.23595 seconds with 10 queries
