Old 02-18-2010, 20:45   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Simoco sm-499 new firmware detected>
SIMOCO SM-499 NEW FIRMWARE DETECTED>
FULL OK SET LOG:-
COM3 [VCP0] selected
module  v3.08
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:8E90:D7C3
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.53E63683.[M678_PCB01_GPRS_MT6226_S01.K558-E_26BV01_01B03.BIN_7B0DDA97].rpl
rom info detection finished
New firmware detected (v.3.08, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 53E63683
rom info ver: 04
sw version: M678_PCB01_GPRS_MT6226_S01.K558-E_26BV01_01B03.BIN
project-id: K558-E_26Bv01.01b03, 97DA0D7B
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: M678_PCB01_GPRS_MT6226_S01.K558-E_26BV01_01B03__fullflash...
warning: wrong data size at 0x00070400, retry...
read error recovered
file saved: C:\Program Files\InfinityBox\ChineseMiracle\M678_PCB01_GPRS_MT6226_S01.K558-E_26BV01_01B03__fullflash_20100219-005646.B0M.bin
PINCONNECTION:- CABLE-L18A RX=4 TX=3
FILE LINK OK SET:-
The Following User Says Thank You to debmobile For This Useful Post:
Old 02-19-2010, 10:29   #2 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
good sharing...........
Old 02-19-2010, 12:57   #3 (permalink)
Member: 1043909
Thanks Meter: 60,926
FULL OK SET LOG:-
module  v3.08
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize Done
====>  Set baud ...
460800
Set baud Done
TCL-ID is absent
device-id: 53E63683
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
FILE LINK OK SET:-
Hello,
Thank you very much !
We will check, prepare and upload files in support area ASAP.
Simoco sm-999 new firmware detected> debmobile Infinity-Box 1 02-11-2010 21:37
Heare is simoco sm-324 new firmware detected debmobile Infinity-Box 5 12-20-2009 16:47
<new model simoco sm-1200 new firmware detected> debmobile Infinity-Box 3 12-07-2009 09:02
Simoco sm-399 new firmware detected debmobile Infinity-Box 2 07-31-2009 17:20
Simoco Sm-498 New Firmware Detected. debmobile Infinity-Box 3 08-08-2008 10:49
Page generated in 0.21648 seconds with 9 queries
