Old 03-11-2011, 05:24   #1 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Infinity team pls check HL2802
I try to unlock it with all method still not good
COM46 [VCP0] selected
module v3.79
Device: Hello-HL2802
Checking data, wait...
Action: "sp-unlock"
unlock method: standard fast
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:73B5:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: C2227E22212201:2AEA0000000000
flash: AMD/Fujitsu std [def 0080x020000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
rom info detection finished
rom info ver: 07
sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.CB-HL-R9DM-P109A21V1_0_0B05.BIN
project-id: CB-HL-R9DM-P109A21V1.0.0B05, 00000000
code offset: 00000000
ffs offset/size [02]: 00880000/00780000
TCL-ID is absent
ffs/eeprom address assigned: 00880000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
lock area found
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
required data found
Write: area 1 (pass 2)
area 1 patch applied Ok
Special operation Done
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 1 min 27 sec
Remove/Install battery now !
the same problem like MF6201
and this log i read code
module v3.79
Action: "sp-unlock"
unlock method: smart fast
Model: Hello-HL2802
19200 autodetect
CPU: MT6223
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: CB-HL-R9DM-P109A21V1.0.0B05
Version: ZTENJ23D_09A_HW
86 byte(s) read
imei: 86515500010991
connection Ok
192 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 24 sec
Pls hlep me.
thanks.
Old 03-11-2011, 08:10   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
module v3.79
Action: "sp-unlock"
Model: Hello-HL2802
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
86 byte(s) read
connection Ok
192 byte(s) read
reading data...
reading data #2...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Pls hlep me.
thanks.
Hello,
First try with "read unlock codes" method.
If not done flash phone with different SFR-115 firmware files from support area and see results.
And do not forget to make full backup first.
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-11-2011, 08:28   #3 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Wr.
tested but still not good and 4 read code method
when i type code code not accepted
pls help me.
thanks.
Old 03-11-2011, 08:34   #4 (permalink)
jumper-master's Avatar
Member: 641971
Thanks Meter: 34
lock area found
lock area found
required data found
required data found
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
Finalization Done
connection Ok
192 byte(s) read
reading data...
reading data #2...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Your phone seem UNLOCKED if NOT than 1st use READ CODES METHOD if not work than you can use ChineseMiracle because your phones CPU is 6223.
The Following User Says Thank You to jumper-master For This Useful Post:
Old 03-11-2011, 09:04   #5 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
pls help me.
thanks.
Hello,
Flash phone with different SFR-115 firmware files from support area and see result.
You can also try with different R221 firmwares and see result.
Wr
Old 03-11-2011, 09:17   #6 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Hello,
Wr
tested still not good.
pls help me.
thanks.
Old 03-11-2011, 09:42   #7 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
where infinity team?
pls help me.
i think u can help me.
thanks.
Old 03-11-2011, 09:49   #8 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Send the original backup file to [email protected]
Also you can try to read unlock code with original/other sim inserted and see result.
Wr.
Old 03-11-2011, 09:51   #9 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Hello,
Wr.
thanks but i tested still not good
code not accepted.
Old 03-11-2011, 15:24   #10 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
i need unlock HL 2802 sim 2.
Infinity team pls help me.
thanks.
Old 03-12-2011, 03:32   #11 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Now is ok 100%
thanks.
Old 03-12-2011, 11:54   #12 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Now is ok 100%
thanks.
Would be good if you post how it became ok since would help other users to solve same problem if faced!
Wr.
Old 03-12-2011, 12:01   #13 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Wr.
1.flash it with ZTE R221
2.use smart fast.
3.ok
4.enjoy
Old 03-12-2011, 12:04   #14 (permalink)
Member: 130995
Thanks Meter: 35,227
2.use smart fast.
3.ok
4.enjoy
Hello,
What R221 firmware file you have used for flashing (6 different files for R221 exist in support area) ?
Old 03-12-2011, 12:53   #15 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Originally Posted by InfinitySupport View Post
Hello,
this file sir for HL 2802
ZTE-R221_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.GRE-WIND-R9DM-P109A17V1_0_2B03_2010-10-18_En_Gr.B0M.bin
but haven't khmer language (all both HL2802 and MF 6201)
Pls help me.
thanks.
Check this New Nokia Tool.. tronix Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 06-01-2001 10:24
5110 V 5.30 CHECK SIM gsnbhagawan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-21-2001 06:45
Wanted 6130 4.02 full backup Pls Read Charly Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-06-2001 05:12
check out my FREE large gsm soft site LaLGsm GSM Mobile Links 0 01-16-2001 04:36
FBUS works but MBUS not! PLS Help! Upo Nokia Hardware & Hardware Repair 5 09-12-2000 14:54
Page generated in 0.25445 seconds with 9 queries
