02-21-2010, 10:03 | #1 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Myphone q21 duo Quote:
thanks.. | |
02-21-2010, 10:13 | #2 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | COM14 [VCP1] selected module v3.03 Device: MyPhone-Q21 Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1E03:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.03, database date: 16.01.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_PR_R 0_2_V7_PHILIPPINES.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_PR_R 0_2_V7_PHILIPPINES.BIN project-id: E500.PR.R0.2_V7_PHILIPPINES, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MyPhone-Q21_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_ PR_R0_2_V7_PHILIPPINES__ffs... file saved: C:\Program Files\InfinityBox\MModule\MyPhone-Q21_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_ PR_R0_2_V7_PHILIPPINES__ffs_20100221-170612.B0E.bin flash: 01227E223C2200:0AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E223C2200:0AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 10 min 17 sec Remove/Install battery now ! AFTER PHONE DEAD...TOTALLY DEAD.. BR. |
02-23-2010, 05:05 | #5 (permalink) |
Major Poster Join Date: Dec 2008 Location: litle alaska philippines Age: 34
Member: 933096 Status: Offline Sonork: inocentedeti Thanks Meter: 19 | same problem here ....!!! Q22 after read flash ... totally dead !!!!!!!!! TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502B_2_P R_R1_0_V5_PHILIPPINES.BIN |
02-23-2010, 05:07 | #6 (permalink) |
Member: 933096 Status: Offline Sonork: inocentedeti Thanks Meter: 19 | COM10 [VCP0] selected module v3.09 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8603:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.09, database date: 16.02.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502B_2_P R_R1_0_V5_PHILIPPINES.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502B_2_P R_R1_0_V5_PHILIPPINES.BIN project-id: E502B_2_PR_R1_0_V5_PHILIPPINES, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502B_2_P R_R1_0_V5_PHILIPPINES__fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMIN I_PCB01_GPRS_MT6225_S00.E502B_2_PR_R1_0_V5_PHILIPP INES__fullflash_20100223-120345.B0M.bin Finished, time used: 22 min 0 sec Remove/Install battery now ! |
02-23-2010, 05:12 | #7 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Midle of the Earth
Member: 575851 Status: Offline Thanks Meter: 544 | here the back-up full flash http://www.uploadmb.com/dw.php?id=1266898204 |
The Following 2 Users Say Thank You to ayhen42 For This Useful Post: |
02-23-2010, 09:01 | #8 (permalink) | |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_PR_R 0_2_V7_PHILIPPINES.BIN but anyway thanks i try to flash that BR | |
02-23-2010, 11:38 | #9 (permalink) | |
You need to check battery voltage value, it may be that battery become empty during flash read process. | |
02-23-2010, 12:06 | #12 (permalink) | |
02-23-2010, 13:15 | #14 (permalink) | |
Why you lie here http://forum.gsmhosting.com/vbb/show...67&postcount=5 ? Please, do not make other users and supporters confuser with false problem description ! What to do now: charge battery with external power supply and follow the instruction that you can see at end of format process (hold phone power button long time) | |
>>> MYPhone T22 DUO lock code done and PINOUT HERE <<< | keaelite | Infinity-Box | 10 | 06-22-2009 19:22 |
Myphone T52 Duo cable pinout??????? | jham | Infinity-Box | 3 | 02-04-2009 16:22 |
Myphone B23 Duo Pinout please?? | jham | Infinity-Box | 1 | 02-04-2009 16:19 |
MyPhone T22 Duo white screen, pls help | kolz07 | Infinity-Box | 1 | 12-15-2008 19:40 |
>>> MyPhone S22 DUO SIM2 SHUTDOWN solved <<< | keaelite | Infinity-Box | 15 | 09-21-2008 01:41 |
