10-12-2015, 07:38 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | need suggestion / help lenovo S850 MTKMT6582 Brand : Lenovo ProdName : scofield_row ProdModel : Lenovo S850 Device : S850 AndroidVer : 4.4.2 MTKxCPU : MT6582 MTKxPRJ : S850_ROW_S119_140627 AFTER FLASH SAME FIRMWARE S850_ROW_S119_140627 WITH CM2MTK 1.33 INFO NOT SHOWN AND MOBILE NOT ON. Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! FLASING SAME FILE WITH SPFTOOL MOBILE OK. WHAT IS THE PROBLEM WITH CM2? LOGS Code: Card found : S/N : XXX , v0129 Chinese Miracle II [MTK module] v 1.33 Scatter Load Ok , BaseBand : MT6582 , Project : scofield_row , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Start at : [10/12/2015 / 11:04:39 PM] Operation : Flash [ v1.33 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D4201A1BDDAF2614B DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4201A1BDDAF2614B [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : scofield_row , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x000000015AC80000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_scofield_row.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : PRELOAD Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:57 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : PRELOAD Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:08 Update RomInfo done Done! Elapsed: 00:06:30 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D4201A1BDDAF2614B DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4201A1BDDAF2614B [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [10/12/2015 / 11:16:23 PM] |
10-12-2015, 07:55 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Malik4u Have to tried Chinese Miracle II [MTK module] v 1.32 cause Chinese Miracle II [MTK module] v 1.33 is in Beta Testing not officially Released by Team???? Waiting for your reply.. B/R Sheraz... |
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post: |
10-12-2015, 08:16 | #3 (permalink) | |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
after imei repair no network issue . How to solve | |
10-12-2015, 08:24 | #4 (permalink) |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected malka4u Please check the Base band if it is ok then go for Sim Management or Sim Services and check these options. Is Imei repair Successfully? If Yes Then Check the Back Sticker for Imei with which digit its starting? If all Failed Then Find Same Mobile and try to read NVRM and write Back to faulty Phone Hope your problem will be solved.. Post The Results: Waiting for reply.. Sheraz... |
10-12-2015, 09:23 | #6 (permalink) |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected malka4u... If All Is Ok For example Repair BB Ok Imei Ok Then Last Step Go For the Same working mobile Read NVRM From that and Write Back to Faulty One if still same then please Go for Hardware Check. Ask For this to *******r were its signals ok before he/she come to you with any problem in the Mobile? B/R Sheraz... BEST OF LUCK... |
10-12-2015, 09:32 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. Repartition. It not power on/read info due disabled repartition. 2. That is ugly lenovo , which mean - every sw version change will bring problems, like nvram damage and e.t.c. , better just use it own version, or find good NVRAM according it baseband version. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
10-12-2015, 11:57 | #8 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | i found solution in your post brother recently i have solve same issue in lenovo tab a3500 hv if you have backup infinity tool scatter file write the file thru cm2 tool and after that read nvram backup with cm2 and flash the tab with sp tool and when set is alive then write nvram via cm2 and after this repair imei all you have done good luck |
01-18-2017, 07:44 | #15 (permalink) | |
No Life Poster Join Date: Nov 2015 Age: 25
Member: 2493574 Status: Offline Thanks Meter: 605 | Dear Bro, Quote:
S850_ROW_S215_150114 ↦ https://cloud.mail.ru/public/2a462aa...215_150114.rar , because this guide is for Lenovo S850 then you need to download Lenovo S850 stock ROM, for another china device then you need to search it on the need. NV_RAM http://www.4shared.com/file/rzUCNB6Iba/NV_RAM.html↦ Lenovo S850 NVRAM block, cannot be use for another device. How to Fixing Lenovo S850 no Service Issued, 100% Work Download all files and place on the same folder, so you can easy to search the needed files. Extract the both files too and then go to flash tool extracted folder, run flash_tool.exe for windows 7 or later please use administrator privilege After you can see the flash tool windows, now press ALT + CTRL + V. This will make flash tool run on Advanced Mode, you can see on the flash tool windows bar. On the Download tab click Scatter-Loading button and the navigate to ROM extracted then select MT6582_Android_scatter.txt this will load all ROM files to flash tool. Click Windows ↦ Write Memory this will add a tab, then select the Write Memory tab, like on the below picture How to Fixing Lenovo S850 no Service Issued, 100% Work Open scatter file that you find on the extracted ROM, using word pad or notepad. Search for NV word, you will see three address on the scatter file linear_start_addr, physical_start_addr and partition_size. Put the linear_start_add on the Begin Address (Hex) and partition_size on the Container Length (Hex) How to Fixing Lenovo S850 no Service Issued, 100% Work Click on Open RAW Data, select the NV_RAM file that already downloaded How to Fixing Lenovo S850 no Service Issued, 100% Work Last click Write Memory button, turn off your device because Lenovo S850 using non removable battery you must make sure that your device is completely turn off, connect your device to flash tool using USB cable and flash tool will recognize your device and begin to start flashing process, wait until you can see GREEN CIRCLE in the middle of flash tool. Done, disconnect then try to turn on your device and normal boot. See if the service already on and can be use on your device. Done, Congratulations i hope your Lenovo S850 already fix Last edited by Shikhar12; 01-18-2017 at 07:52. Reason: url editting | |
