11-14-2015, 12:54 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Connect cable to phone Go to required software page Click to required software button Follow by instruction given by software |
11-14-2015, 13:16 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @muzammal mudass, To read firmware first select correct Cpu/Platform under Settings tab, then go to Flash tab and press read Flash. Incase you want to read factory firmware (which is always best), just mark check on Read Factory File and then read firmware. If you want to read code- For FP- just select correct CPU under Settings tab, go to UserData tab, check on Read Codes box and press on Reset User Code. For Sp- select correct CPU under Settings tab, go to UserData tab, check on UserDataSafe box, and press button infront as required from three buttons (pattern, privacy and user). Any more problem ask here. Anyway, CM2 GUI is already so simple that you can see and understand all tabs and button yourself easily. Also just move your cursor on all buttons one by one and you can see it's feature and info right there. Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
