07-25-2008, 17:20 | #1 (permalink) |
Insane Poster Join Date: Feb 2005 Age: 45
Member: 114712 Status: Offline Thanks Meter: 5 | infinitysupported need your help! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! that is the logs,even i dont press hold the power it gives like this answer! what sould i do to solve this kind problims???? and also i cannot used the pinfinder coz everytime i connect say update the dongle...how can update the dongle and how can use it properly! tnx. |
07-25-2008, 18:01 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You must select correct COM port !!! You have selected wrong COM port and you must select correct one ! |
07-25-2008, 19:36 | #3 (permalink) | |
Member: 114712 Status: Offline Thanks Meter: 5 | Quote:
and also the others com port is error only com port3 working! theres any other idea for this or can i have your ym? or this is my ym [email protected]. pls help me for this problim! | |
07-25-2008, 20:06 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Did you ever tried to use Infinity-Box before ? What COM port you have selected before ? |
07-25-2008, 20:28 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What sw you talk about exactly ? Did you ever tried to use Infinity-Box before ? Did you ever tried to use any other Infinity-Box software before ? |
07-26-2008, 12:45 | #7 (permalink) |
No Life Poster Join Date: Mar 2006 Location: PAKISTAN/MULTAN
Member: 242838 Status: Offline Thanks Meter: 83 | i hav also infinity pinfinder i hav Updated it but it give me Erorr continusly software version: 1.11 cable type: 2x5 (L10C) platform: MT62xx (autodetect) searching adapter at COM16... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... too many retries too many retries connection w/adapter lost during set Tx as pin 7 failed to detect pins time required: 6 sec too many retries too many retries too many retries Power On ! |
07-26-2008, 13:05 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, download PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf Please, see page 19: Automatic pinout detection: Troubleshooting |
07-27-2008, 09:58 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Did yopu checked installation manual carefully ? Please, open installation manual and make box installation according to instruction. Also you will see pictures in installation manual, check your PC after installation and be sure that everything installed correctly. Check pictures in manual ! |
07-30-2008, 18:54 | #11 (permalink) | |
everything is complete installition...but now the problem when i connect the phone and do read full flash...appear on SW press and hold power button now! but the problem even i press and hold the power button still the same appears on SW! i did follow all the manual instruction on the supported area but still got this kind problems. THE COM PORTS IS CORRECT. V2.50 SW! what should i do? | |
07-31-2008, 10:53 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if com port is set correctly it is either a cable or phone internal problem |
Need your help | murtaza_k | Nokia Base Band 5 ( BB-5 ) | 3 | 03-29-2010 20:09 |
InfinityHelp i need your help. need pinouts | IkaMazini | Infinity-Box | 3 | 02-22-2008 20:04 |
Please I need Your Help Chinese Phone. Please Help | pradeeprajmbbs | Chinese Models & Cloned Phones | 6 | 01-28-2008 19:21 |
Please help for DEAD L6, need your help! | KUBAT1 | Motorola P2k | 5 | 03-30-2006 18:57 |
Please help me i need your help!!! | NeCtAr | E-Gold Based Phones | 1 | 04-22-2004 22:06 |
