03-15-2023, 13:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | INFINIX HOT 12 PLAY ( X6816) SMART RESET Done CM2 Code: Operation: Reset Settings/Format FS [ v2.38c7 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM; PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 87C85E667973C4496837D432E3864939 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: E93611CEB9B18471DFB90C5920DDE078EDC31640A699CABD391746C1EECF13AA BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: Infinix: SECURE_BASE | Manual: Off [2ef94f72] C:\InfinityBox\CM2MT2\boot\Infinix\SECURE_BASE\MTK_AllInOne_DA_SWSEC.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 9B0100593250303634002883442F4989 VEN: Hynix OEM: 0 ID: 593250303634 [Y2P064] PRV: 0x00 SNN: 679691311 [0x2883442F] MF: 4/2022 EMI: FireFly preloader_x6816_xq683.bin with 4 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x00080000 [ 512.00 KB ] DRAM 0x100000000 [ 4.00 GB ] EMMC: CID: 9B0100593250303634002883442F4989 VEN: Hynix OEM: 0 ID: 593250303634 [Y2P064] PRV: 0x00 SNN: 679691311 [0x2883442F] MF: 4/2022 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D942264FC0038911A08C8378ABDFD903 MEID: 87C85E667973C4496837D432E3864939 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 24188 [12|24188|0] Scan filesystem... SmartInfo: AndroidVer: 11 UserDataFS: 0x03 CacheFS: 0x02 Strategy: 7 Verify device config... Finished Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__87C85E667973C4496837D432E3864939 Process: RESET PROTECTION... Format Ok: RESET PROTECTION Process: USERDATA... Format Ok: USERDATA Process: USERDATA... Format Ok: USERDATA Process: USERDATA... Format Ok: USERDATA Done: 00:00:30 Reconnect Power/Cable now |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
