03-16-2023, 20:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | INFINIX HOT 12i X665 REPAIR IMEI Done Code: Operation: Repair Security [ v2.38d1 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM3) MODE: BOOTROM; PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 01156C5D2093AEB4EA1C85AB30C8EB28 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 0DAA4DF8464D9BEC879118FA0D82611C731F7CAD0104BF9DC798D0930686BBD1 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI not found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: On [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin [f3b722d0] C:\Users\Yuran Williams\Downloads\Telegram Desktop\preloader_x665_h6126.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 15010043555441343205612C8D546821 VEN: Samsung OEM: 0 ID: 435554413432 [CUTA42] PRV: 0x05 SNN: 1630309716 [0x612C8D54] MF: 6/2021 EMI: MT6761 preloader_x665_h6126.bin with 4 memory type(s) supported 00: DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 512.00 MB ] 01: DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] 02: DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] 03: DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] EMI: Init EMI from PRELOADER EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A500 [ 233.25 KB ] DRAM 0x80000000 [ 2.00 GB ] EMMC: CID: 15010043555441343205612C8D546821 VEN: Samsung OEM: 0 ID: 435554413432 [CUTA42] PRV: 0x05 SNN: 1630309716 [0x612C8D54] MF: 6/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 311A3D907CBD2C7A76C8F3135D942E3A MEID: 01156C5D2093AEB4EA1C85AB30C8EB28 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok NVRAM: Items: 0xA2 Size: 0x08C12D State: Ok WiFi MAC: AA0036004400 BlTh MAC: AC29298D27E6 IMEI[1]: 359237685116506 IMEI[2]: 359237685116514 Set IMEI[1]: 355555444444115 Set IMEI[2]: 354846465555553 Update NVRAM... Update NVRAM Ok Update dependencies... Update dependencies Ok Reading... Scan memory... Found region: 25600 [12|25600|0] Scan filesystem... Startegy: 7 Done: 00:01:12 Reconnect Power/Cable now |
The Following User Says Thank You to yuranc8 For This Useful Post: |
