01-09-2021, 14:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | jazz digit 4g latest version repair faild solution needed Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.16 Load IDBase v1118158 Ok! Update configuration ... Update Ok! Load IDBase v1118158 Ok! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 02059F2C5F254564BF3378FCA403F15C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : E5E2D6EA85BE8E64FC96BA4CDA43E82BF4FEEAFC5E78BBCD23 DD8F92F85B7516 BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739,S01 AP_SWTM : Fri Oct 16 18:04:07 CST 2020 AP_SWVR : alps-mp-m0.kaios.mp1-V1.2_fise6731.kaio.m_P5 AP_HWVR : S01 MD_CHIP : MT6739 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V118.5.P3 MD_SWVR : FISE6731_KAIO_M_HW MD_HWVR : Unknown Done! Elapsed: 00:00:56 Operation : Repair Security [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739,S01 AP_SWTM : Fri Oct 16 18:04:07 CST 2020 AP_SWVR : alps-mp-m0.kaios.mp1-V1.2_fise6731.kaio.m_P5 AP_HWVR : S01 MD_CHIP : MT6739 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V118.5.P3 MD_SWVR : FISE6731_KAIO_M_HW MD_HWVR : Unknown IMEI[0] : 3ccccccccccccccccc IMEI[1] : 3ccccccccccccccccc IMEI[0] : 000000000000000 Item : update Failed! [ 0x0018 ] Done! Elapsed: 00:00:44 Reconnect Power/Cable! Operation : Repair Security [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : E5E2D6EA85BE8E64FC96BA4CDA43E82BF4FEEAFC5E78BBCD23 DD8F92F85B7516 BROM : Configuring target for META BROM : META configured! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Repair Security [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : E5E2D6EA85BE8E64FC96BA4CDA43E82BF4FEEAFC5E78BBCD23 DD8F92F85B7516 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6739,S01 AP_SWTM : Fri Oct 16 18:04:07 CST 2020 AP_SWVR : alps-mp-m0.kaios.mp1-V1.2_fise6731.kaio.m_P5 AP_HWVR : S01 MD_CHIP : MT6739 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V118.5.P3 MD_SWVR : FISE6731_KAIO_M_HW MD_HWVR : Unknown IMEI[0] : 3ccccccccccccc IMEI[1] : 35ccccccccccccc IMEI[0] : 000000000000000 Item : update Failed! [ 0x0018 ] Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
