10-01-2021, 21:15 | #1 (permalink) |
Junior Member Join Date: Jan 2021 Location: Nigerian, Abia
Member: 2979006 Status: Offline Sonork: 100.1684640 Thanks Meter: 0 | infinix pr652b dead solution BootVersion : SPRD3 Boot : PAC : PR652B -F6317 -11.0-OP -V032 -20210605 . pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Prepare target ... ERROR : 0000008E:80000000FF7F7E00 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! >>> Error : Flashing failed! >>> Check previous message for more info! Reconnect Power/Cable! |
06-29-2022, 21:51 | #8 (permalink) |
Junior Member Join Date: Jan 2022 Location: Nigeria, South East
Member: 3006044 Status: Offline Thanks Meter: 4 | Make sure you load a .PAC file and not a cm2 backup. Untick flash format then flash. Make sure you're logged in to your cm2 account and you have internet connection. After successful flash, you can tick nvram update and flash again |
The Following User Says Thank You to Emmanus1 For This Useful Post: |
