10-11-2021, 19:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: pakistan
Member: 2767415 Status: Offline Thanks Meter: 30 | infinix pr652b format error Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! VER : BP_R2.0.1 LEN : 10B609F1E ( 4.18 GiB ) CPU : s9863a1h10 VER : PR652B-F6317-11.0-OP-V046-20210830_2008 Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR652B-F6317-11.0-OP-V046-20210830.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : Access denied: {"Message":"Access denied `00B6BA133E` auth"} >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
10-12-2021, 09:08 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Read log carefully- Quote:
Br. Infinity-Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
12-19-2021, 04:08 | #6 (permalink) |
Junior Member Join Date: Dec 2019 Location: Philippines
Member: 2941030 Status: Offline Thanks Meter: 0 | Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! |
12-19-2021, 06:40 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Easy. Just enter VALID username and password from your Infinity Online Services account. | |
01-02-2022, 16:39 | #8 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | Operation : Format FS / Reset Settings [ v2.09 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR652B-F6317-11.0-OP-V036-20210708.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0xE8EECADC ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Wipe failed! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:08 |
01-02-2022, 16:39 | #9 (permalink) |
01-02-2022, 16:44 | #10 (permalink) |
Member: 2266425 Status: Offline Thanks Meter: 58 | infinix PR652b write flash failed? Operation : Flash Firmware [ v2.09 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR652B-F6317-11.0-OP-V036-20210708.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0xE8EECADC ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x4A PMTMng : Update failed! ERROR : 000000B9:B9000000FF467E00 GEN : UNKNOWN RESPONSE! >>> Error : Flashing failed! >>> Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process |
01-02-2022, 17:17 | #11 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
11-10-2022, 21:55 | #13 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote: | |
