10-12-2016, 11:15 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | Istar i7 plus mtk6580 version 6-imei rebuild success-but still invalid imei Operation : Repair Security [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 109 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838434538011EDB4BA473C5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EC8H [eMMC] : FLASH_CID : 700100454838434538011EDB4BA473C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x76D40596D1D06A2A02A77B903AB06ACD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 355071501444535 IMEI [01] : 355071501444543 IMEI [02] : 861622010000056 IMEI [03] : 861622010000056 Set IMEI [00] : 353673058789402 Set IMEI [01] : 353673058789402 Prepare finished. Security check required! Wait for phone... Phone found! [ 109 ] Sync... Repair done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! what i do as a next step? |
The Following User Says Thank You to zone3 For This Useful Post: |
10-12-2016, 12:08 | #2 (permalink) |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Hello, Check Baseband Then do repair imei.. |
The Following User Says Thank You to tapas770 For This Useful Post: |
10-13-2016, 06:35 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Bro Zone3.. What was the condition of mobile before flashing? Did you tried this phone on flashing and its done flashing with Normal ON? Now IMEI write done but same is it your problem? Solution: Try to write same SPNV if available of that file which you used for flashing. Your problem will be solved. B/R Sheraz... |
10-14-2016, 04:29 | #6 (permalink) |
Member: 946381 Status: Offline Thanks Meter: 150 | did-logs as below Operation : Reinit Modem [ v1.51 ] Wait for phone... Phone found! [ 109 ] Sync... Modem reinitialize done! Done! Reconnect Power/Cable! then again rebuild imei-logs as below Wait for phone... Phone found! [ 109 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838434538011EDB4BA473C5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EC8H [eMMC] : FLASH_CID : 700100454838434538011EDB4BA473C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x76D40596D1D06A2A02A77B903AB06ACD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 355071501444535 IMEI [01] : 355071501444543 IMEI [02] : 861622010000056 IMEI [03] : 861622010000056 Set IMEI [00] : 353673058789402 Set IMEI [01] : 353673058789402 Prepare finished. Security check required! Wait for phone... Phone found! [ 109 ] Sync... Repair done! Done! Elapsed: 00:00:46 Reconnect Power/Cable! first time on imei ok-again on and off imei invalid is my problem |
02-28-2017, 17:48 | #11 (permalink) | |
Insane Poster Join Date: Jan 2011 Location: Pune 9763827863
Member: 1493682 Status: Offline Thanks Meter: 12 | iStar i7 Quote:
after imei repair it shows new imei, but after restarting it same as old imei. | |
The Following User Says Thank You to smc_313 For This Useful Post: |
03-09-2017, 12:35 | #12 (permalink) |
Crazy Poster Join Date: Nov 2014 Location: india
Member: 2295090 Status: Offline Thanks Meter: 20 | same problem for me too but my problem was solved after flashing flash in sptool with format all+download after flash nv ram data will be changed and after that imei repair we can do restart or factory resetting the imei will be same... with full bar of network signal |
The Following User Says Thank You to ajjjuajjj For This Useful Post: |
