07-04-2019, 08:22 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | infinix x627 flashing error Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM171) MODE : PRELOADER PORT PORT : 171 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 700100544132383332232F8E9A7E4647 EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3FD70A40E2DEB717A84B847CF35B445D DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X627-H624STXYZAa-P-190418V169 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-04-05 Build Time : 1555581745 Product Model : Infinix X627 Product Brand : Infinix Product Name : H624 Product Device : Infinix-X627STU Product Manfct : INFINIX MOBILITY LIMITED Product Info : x627_h624 Product Board : Infinix-X627 Board Platform : mt6761 USERDATA : ENCRYPTED Done! Elapsed: 00:00:24 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 700100544132383332232F8E9A7E4647 EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3FD70A40E2DEB717A84B847CF35B445D DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) OK SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000009B00000 Erase : 0x000000000DB00000 : 0x00000000C6D00000 Erase : 0x00000000D8800000 : 0x000000000E900000 Erase : 0x00000000E7400000 : 0x0000000016280000 Erase : 0x00000000FF680000 : 0x00000000C4180000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO ERR : 0xC002002A ERR : SEC_IMG_TYPE_MISMATCH ERR : 0x00800000|0x00800000 Error : Flashing failed! Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
07-04-2019, 13:32 | #5 (permalink) | |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 492 | Quote:
07-04-2019, 15:31 | #6 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | "ERR : SEC_IMG_TYPE_MISMATCH" Are u sure this is signed firmware or it's just a dumpr Sent from my SM-G955U1 using Tapatalk |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
09-03-2019, 15:02 | #8 (permalink) |
Freak Poster Join Date: Jan 2019 Location: Nigeria
Member: 2889735 Status: Offline Thanks Meter: 7 | cm2mt2 error 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT0717 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
09-04-2019, 10:45 | #9 (permalink) |
Member: 2889735 Status: Offline Thanks Meter: 7 | flash done but seems phone userdata still corrupt and did not clear even after factory rest Preloader [HW DEV] Info : EMI : DEV : MT6761 EMI : SRC : preloader_x627_h624.bin EMI : CNT : 000A EMI : [00] : : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [02] : : VEN : FORESEE | DEV : SLD32b : RAM : [ 2.00 GB ] EMI : [03] : : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [04] : : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [05] : : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [06] : : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [07] : : VEN : UNKNOWN | DEV : : RAM : [ 1.00 GB ] EMI : [08] : : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [09] : : VEN : UNKNOWN | DEV : : RAM : [ 1.50 GB ] Operation : Write Flash [ v2.06 ] Repartition : Disabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Files :21 [FL] : Set : md1img-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : sspm-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot.img [FL] : Set : logo-verified.bin [FL] : Set : dtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : recovery.img [FL] : Set : tkv.img [FL] : Set : tranfs.img [FL] : Set : userdata.img [FL] : Total size : 0xAF61F39C [ 2.74 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 70010054413238333223263A441146E1 EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B815674932939C78DB440968AEE08432 DA : USB : HIGH-SPEED Boot done! SEC_DL : False (RAPHAEL) OK SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Flashing now ... Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : VBMETA Write : CACHE Write : RECOVERY Write : TKV Write : TRANFS Write : USERDATA SEC_DL : False (RAPHAEL) OK SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Flashing finished! Done! Elapsed: 00:01:58 Reconnect Power/Cable! |
