05-02-2021, 21:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | infinix x682b not properly connect with infinity Card found : 53471D69 , v0148 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.22 Load IDBase v428174 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 46BADBCDC75873CB3CB7FE3BF24DB9DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : CF6F096F56B8A682699233786E82741E68C2DF862DBED44E60 4346E2CD262189 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Boot done! Done! Elapsed: 00:00:41 Reconnect Power/Cable! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 46BADBCDC75873CB3CB7FE3BF24DB9DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : CF6F096F56B8A682699233786E82741E68C2DF862DBED44E60 4346E2CD262189 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 46BADBCDC75873CB3CB7FE3BF24DB9DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : CF6F096F56B8A682699233786E82741E68C2DF862DBED44E60 4346E2CD262189 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 46BADBCDC75873CB3CB7FE3BF24DB9DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : INFINIX : SECURE_BASE | Manual : Disabled BROM : SOCID : CF6F096F56B8A682699233786E82741E68C2DF862DBED44E60 4346E2CD262189 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 46BADBCDC75873CB3CB7FE3BF24DB9DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : INFINIX : SEC_NEW | Manual : Disabled BROM : SOCID : CF6F096F56B8A682699233786E82741E68C2DF862DBED44E60 4346E2CD262189 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 46BADBCDC75873CB3CB7FE3BF24DB9DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled BROM : SOCID : CF6F096F56B8A682699233786E82741E68C2DF862DBED44E60 4346E2CD262189 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 46BADBCDC75873CB3CB7FE3BF24DB9DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : CF6F096F56B8A682699233786E82741E68C2DF862DBED44E60 4346E2CD262189 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
05-07-2021, 13:31 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | CM2MT2 v2.23 released, it may helps https://www.infinity-box.com/support/?r=100149 |
05-08-2021, 18:43 | #6 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Select Infinix, Select Raphael, Tick Reboot, Connect phone WITHOUT button key |
The Following 2 Users Say Thank You to Yusuf Lawal For This Useful Post: |
