Old 08-29-2019, 01:48   #1 (permalink)
Member: 2153016
Thanks Meter: 29
infinix_ X624B DEAD AFTER READ INFO ONLY !!!
hi every one i got infinix_ X624B with pattern so i do read info with cm2 1.58 with corect DA file and every thing was ok
so i traid to read pattern i get error and phone dead after that
first log for info
Start at : [26/08/2019 / 09:11:50 م]
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.2017/12/29.10:21_396299
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9C
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A484247346132A420001225925D
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A420001225925D
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xCE3B2747180FCEFBA342ADC9D7095004
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Infinix
ProdName : H8026
ProdModel : Infinix X624B
Device : Infinix-X624B
AndroidVer: 8.1.0
MTKxPRJ : X624B-H8026IJK-O-190620V239
SECURITY :
IMEI_SW [1] : 352401108135082
IMEI_SW [2] : 352401108135090
BTMAC Addr : 74C17D456967
WiFi MAC : 74C17D4939F7
Done!
Elapsed: 00:00:17
Reconnect Power/Cable!
and here log of error
Start at : [26/08/2019 / 09:12:46 م]
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 35 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
[DA_ERROR] : 00007017
Boot Error!
Operation Failed
Elapsed: 00:00:22
what can i do to get it alive again
by the way i tray many tools to flash it but no way i get the sam error
thanks for help ...
Old 08-29-2019, 02:04   #2 (permalink)
Member: 2153016
Thanks Meter: 29
i see from info log that
and it become Erased with read patter why ???
Old 08-29-2019, 09:44   #3 (permalink)
Member: 2812901
Thanks Meter: 494
Remove the battery and insert it back.
The Following User Says Thank You to Oyetunde Semiu For This Useful Post:
Old 08-29-2019, 16:47   #4 (permalink)
Member: 2153016
Thanks Meter: 29
i do that many times no way
the problem is preloder erased !!! why ???
Old 08-29-2019, 17:14   #5 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,363
Hello,
Strange condition.
Try to Init Preloader and check result, should be ok.
Next time use CM2MT2 module.
Br.
Infinity-Box Team.
Old 08-29-2019, 17:56   #6 (permalink)
Member: 2153016
Thanks Meter: 29
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Strange condition.
Br.
Infinity-Box Team.
i traid this many time but no luck same error
thankes
Old 08-30-2019, 04:25   #7 (permalink)
Member: 2500215
Thanks Meter: 432
It is the problem of the phone. It is coincidence. A Nokia 3 died on read info still. The phone was destined to die.
That's what happened. Read info doesn't kill phone
Old 08-30-2019, 15:39   #8 (permalink)
Member: 1677653
Thanks Meter: 2,771
first log for info
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : Infinix
ProdName : H8026
AndroidVer: 8.1.0
SECURITY :
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 35 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:22
thanks for help ...
You must be a learner, you want to read pattern lock from Android 8 device?
Do you see in CM2MTK V1.58 update news that it supported Read Pattern Lock on Android 8?
Congratulation to you Sir.
Old 08-30-2019, 16:09   #9 (permalink)
Member: 2812901
Thanks Meter: 494
If anyone has the solution to assist him, let us do that. He had already learned a lesson.
Old 08-30-2019, 16:16   #10 (permalink)
Member: 2812901
Thanks Meter: 494
Everyone of us started from somewhere.
If we have an assistant to render, let us do that. But I don't think to read patterns can killed phone.maybe something wrong somewhere. Unless otherwise he should take it to Carl care (customer care service center) if he never loose the phone. That's all.
Old 08-30-2019, 16:25   #11 (permalink)
Member: 2812901
Thanks Meter: 494
first log for info
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : Infinix
ProdName : H8026
AndroidVer: 8.1.0
SECURITY :
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 35 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:22
thanks for help ...
My own suggestion ! Use MTK MT2 v2.06 to read info and post results here. After we will know the next thing to do. May be you will need auth file to flash it ,we check it on your readed info.
Old 08-30-2019, 16:43   #12 (permalink)
Member: 1677653
Thanks Meter: 2,771
thankes
Download below firmware, please flash with Aftersales Flash Tool.
Make sure you hold both volume key till FLASH DONE.
****************************/file/y9t8h...obile.zip/file
Old 08-31-2019, 02:03   #13 (permalink)
Member: 2153016
Thanks Meter: 29
thankes for replay
Normal when trying to read the pattarn phone still alaive even if not supported on the dongle and not to die phone !!!
any way i will try your firmware and post replay
thankes to all friends who replay ,,,
Old 08-31-2019, 02:37   #14 (permalink)
Member: 2153016
Thanks Meter: 29
MR Yusuf Lawal
i try to flash it with your firmware but sam error see
File sharing and storage made simple
and i hold both volume key ,, Is there another solution you can try?
thankes again for help ,,,
Old 08-31-2019, 02:49   #15 (permalink)
Member: 2153016
Thanks Meter: 29
thankes for replay
if you have auth file for this phone please give me link because another toll say Please select the auth file first when i try to flash on it ,,
thankes for help ,,,
The Following User Says Thank You to waleedwww For This Useful Post:
Page generated in 0.25347 seconds with 8 queries
