Old 06-04-2008, 08:42   #1 (permalink)
Member: 701311
Thanks Meter: 55
Attention Infinity Team, vodofone225 write failed
I was trying to flash the firmeware from support area, It says write failed
I also tried all firmwares from supprt area and remains the same.
Here is the one of the log I tried:
Loading file v.02...
ZTE-225_main_EH-HU-P108A2V1.0.0B03__VDF-P108A2B07-Hu-HU03_g3dBV2.0.B1M.bin loaded
COM14 [VCP0] selected
Device: ZTE-225, Vodafone-225
Checking data, wait...
Action: flash write
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 00BF:7353
Connecting Done
Check hardware...
flash chip supported
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: Firmware
Writing: Firmware
repair write error [00401000]...
error: write failed[00400000]
Write Failed
Finished, Remove/Install battery now !
Time used: 31 sec
Please help me
Thanks in advance
Old 06-04-2008, 14:37   #2 (permalink)
Member: 130995
Thanks Meter: 35,228
Hello,
We will try to check what is the problem ASAP.
Also, you can try to flash phone by selecting Huawei-T201 model.
Old 06-04-2008, 15:23   #3 (permalink)
Member: 701311
Thanks Meter: 55
Thanks Team for ur reply i tried to Huawei T 201
But all in vain.
Here is the log
ZTE-225_Main_VDF-P108A2B06-ArFr-EG04_g3dBV2.0_May-29-2007.B1M.bin loaded
ZTE-225_ffs_ZH_P108A9V1.0.0B05.B1S.bin loaded
Device: Huawei-T201
Action: flash write
Boot...
loading...
next part...
error: can't run main loader:
Time used: 5 sec
I hope Team Will help Me soon regards
Thanks
Old 06-05-2008, 05:25   #4 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Originally Posted by fazalkhaalid View Post
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
[/B]
It's so high speed for this E-Gold derivative phone ... same problem will appear sometime ( mostly on Vodafone ( ZTE ) 227 i was count ) if you use and other tools like MT-Red or Furious on this baud rate... so - easy is to make it lower - atleast there not so big flash image .
Old 06-05-2008, 15:58   #5 (permalink)
Member: 701311
Thanks Meter: 55
I tried also changing baud rate but still same problem. Please any one help me regards
Thanks in advance
Attention infinity team LG CDMA RDxxxx models gunjan1 Infinity-Box 4 07-26-2009 10:02
attention infinity team nadeem ahmad Infinity-Box 2 04-22-2009 17:09
Infinity team attention please prime_master786 Infinity-Box 7 11-19-2008 15:14
Infinity Team Give Attention RUVAIZ Infinity-Box 2 02-20-2008 15:57
Attention Infinity Team.....can You Unlock C115? bengrippin Infinity-Box 6 08-10-2006 19:43
Page generated in 0.19555 seconds with 9 queries
