12-24-2015, 08:14 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | [Info] : MTK eMMC RO testing Also, there is well-known problem "Encryption Unsuccessful", when mobile ask for reset settings again and again. ( This problem can be solved by "Repair ExtData or "Reset Settings + Repair FS" feature in "Service Tab" ) Reason of this problem can be eMMC "ReadOnly" state. In simple words : mobile came to that state, when eMMC block write on it due much bad block/errors to avoid data loss. How to check and make sure in that? Then is new feature, called "Hw Testing" , select "Flash IC" test and run it. After test will be finished - SW let you know result : Code: [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE7000000 , 3696 MiB [eMMC] : CID : 90014A4834473164048xxxxxxxxxxxx [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! If there is some problem with eMMC, you will see next log : Code: [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE7000000 , 3696 MiB [eMMC] : CID : 90014A4834473164048xxxxxxxxxxxx [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! |
The Following 26 Users Say Thank You to JayDi For This Useful Post: |
12-24-2015, 11:25 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | another boom will blast soon will be if log show same like color codes |
The Following 4 Users Say Thank You to Faheem Anjum For This Useful Post: |
12-24-2015, 11:49 | #3 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | Quote:
The Following 2 Users Say Thank You to partycrasher131 For This Useful Post: |
12-24-2015, 12:58 | #5 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | thanx... you shared the solution which was important |
The Following User Says Thank You to khalidjan For This Useful Post: |
12-24-2015, 13:40 | #6 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | G00d Idea. Thank You Quote:
12-24-2015, 17:19 | #9 (permalink) |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | @JayDi while init preloader please make flash info/ cid supported by bootloader first just like Code: BL : BBID supported by BootLoader! Flash Info : FlashID [0] CID : 90014A2058494E5948 , Name : XINYH , Vendor : 90 , [HYNIX] FlashID [1] CID : 1501004E4A5330304D , Name : NJS00M , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [3] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 130 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A1740C611B DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A1740C611B [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 1799 PartTable Init Failed, Reflashing required! All Done Done! it is very usefull info for hardware repair especially for totally dead emmc WBR |
12-24-2015, 17:55 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @dereje, thanks for the info. Will check it and fix in next release. What "Preloader Init" says? mobile state? Does it alive? working normal? |
12-25-2015, 08:56 | #15 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | hi boss... acer z130 MT6572__acer__Z130__ZX__4.2.2__ALPS.JB3.MP.V1 phone state is hang on logo.. try to flash with cwm always failed, i cant find stock rom for spft.. and i make test Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447020BF18CDE709B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020BF18CDE709B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : acer ProdName : zx_aap_gen1 ProdModel : Z130 Device : ZX AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_P6_1_wg_n EXTRA : LCD [0] : hx8357B LCD Res : 480x320 TOUCH [0] : msg2133a CAM [0] : s5k5cagx_yuv MODEM : cci72_we_jb3_hspa LOCALE : en_US en_AU hi_IN in_ID ms_MY th_TH zh_TW my_MM km_KH mdpi Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : HW Test [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447020BF18CDE709B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020BF18CDE709B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3693 mV [Processing] FlashMemory Read-Write test [eMMC] : [KINGSTON] , G40CM , 0xE2C00000 , 3628 MiB [eMMC] : CID : 7001004D4D43303447020BF18CDE709B [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! |
