Old 09-27-2010, 06:37   #1 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 813
[info] vodafone 543 successfully unlock
COM9 [VCP5] selected
module v3.60
Device: Alcatel-543X
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:1A03:A002
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.xxxxx x.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: xxxxxx
rom info ver: 07
sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN
project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 264
provider: 543X-2AVDGB1
customization: CN26FC01
customization: XN26FC01
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35982003108752
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_xxxxxx_35C4274A_20100927-130026.B0X.bin
Finished, time used: 4 min 18 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
br
freddy
www.gsmph.com
The Following 5 Users Say Thank You to fred For This Useful Post:
Old 09-28-2010, 05:48   #2 (permalink)
Member: 150457
Thanks Meter: 16
HI MATE,
Which cable did you use?
Regards.
Old 09-28-2010, 15:37   #3 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
Old 09-29-2010, 22:31   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by kife View Post
HI MATE,
Regards.
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
RJ45 connector pinout:
Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum
Old 09-30-2010, 04:08   #5 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 813
@InfinitySupport
sorry for the late reply
CPU: MT6225
can be detected by any auto pinfinder due to its cpu type..
br
freddy
The Following User Says Thank You to fred For This Useful Post:
Old 09-30-2010, 05:41   #6 (permalink)
nishue's Avatar
Member: 576633
Thanks Meter: 392
Me tooo,
Vodafone 543 Country Unlock OK !
COM10 [VCP0] selected
module v3.58
Device: Vodafone-543
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:EC03:A00F
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.373C7 337.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl
TCL-ID detection...
device-id: 373C7337
rom info ver: 07
version: 264
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35982003067029
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_373C7337_35C4274A_2010092 9-150716.B0X.bin
Finished, time used: 3 min 38 sec
thanks teem !
The Following User Says Thank You to nishue For This Useful Post:
Old 10-10-2010, 08:30   #7 (permalink)
GsmoneTeam's Avatar
Member: 1978253
Thanks Meter: 34
COM8 [VCP4] selected
module v3.62
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:9B03:A005
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C9838 EC8.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl
TCL-ID detection...
device-id: C9838EC8
rom info ver: 07
version: 264
TCL-ID is present
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35982003232704
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_C9838EC8_35C4274A_2010101 0-122807.B0X.bin
Finished, time used: 4 min 41 sec
thx infinty teem
The Following User Says Thank You to GsmoneTeam For This Useful Post:
Old 10-13-2010, 10:38   #8 (permalink)
Member: 74915
Sonork: no
Thanks Meter: 22
Alcatel/vodafone 543x pinout
c:\Program Files\InfinityBox\pinout\Alcatel-OT363.jpg
Old 10-13-2010, 19:08   #9 (permalink)
bcnboy's Avatar
Member: 12126
Sonork: 1575463
Thanks Meter: 199
LG GW300 cable compatible, tested ok
bcnboy
The Following 5 Users Say Thank You to bcnboy For This Useful Post:
Old 10-22-2010, 15:16   #10 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 03335548581
Thanks Meter: 1,607
bcnboy
today tested with gw300 cable
COM6 [VCP0] selected
module v3.62
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001703:A00A
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.18072 D01.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl
TCL-ID detection...
device-id: 18072D01
rom info ver: 07
version: 264
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35982003143061
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_18072D01_35C4274A_201010 22-191439.B0X.bin
Finished, time used: 4 min 25 sec
The Following 3 Users Say Thank You to Y2ksalman For This Useful Post:
Old 10-28-2010, 13:41   #11 (permalink)
Registered User
Member: 595504
Sonork: 100.1580419
Thanks Meter: 249
COM3 [VCP0] selected
module v3.59
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:4303:A00C
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.335B7 BF9.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl
TCL-ID detection...
device-id: 335B7BF9
rom info ver: 07
version: 264
provider: 543X-2AVDRO1
customization: CN26FP01
customization: XN26FP01
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35982003223032
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_335B7BF9_35C4274A_2010102 8-153542.B0X.bin
Finished, time used: 4 min 26 sec
a have bakup full flash, if moderator want a will sent just mail adress
just use gw300 cable
The Following User Says Thank You to ServiceTEL For This Useful Post:
Old 11-15-2010, 13:42   #12 (permalink)
asif ali's Avatar
Member: 388647
Sonork: sheerazi
Thanks Meter: 161
VODAFONE 543 unlock done
COM4 [VCP0] selected
module v3.64
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:2A03:A00A
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.077B1 259.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl
TCL-ID detection...
device-id: 077B1259
rom info ver: 07
version: 264
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35982003229837
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_077B1259_35C4274A_201011 15-173434.B0X.bin
The Following User Says Thank You to asif ali For This Useful Post:
Old 11-15-2010, 18:08   #13 (permalink)
asif ali's Avatar
Member: 388647
Sonork: sheerazi
Thanks Meter: 161
unlock done
module v3.64
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:9703:A009
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C6709 10E.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl
TCL-ID detection...
device-id: C670910E
rom info ver: 07
version: 264
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35982003268897
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_C670910E_35C4274A_201011 15-220237.B0X.bin
Finished, time used: 5 min 19 sec
The Following 2 Users Say Thank You to asif ali For This Useful Post:
Old 02-02-2011, 10:12   #14 (permalink)
rocky telecom's Avatar
Member: 808657
Sonork: 100.1590300
Thanks Meter: 112
COM6 [Serial0] selected
module v3.73
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:FE03:A00A
status: 01
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is present
startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.9A402 8AE.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl
TCL-ID detection...
device-id: 9A4028AE
rom info ver: 07
project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81
version: 267
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35982003181541
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_9A4028AE_814E5441_201102 02-011200.B0X.bin
Finished, time used: 4 min 24 sec
The Following User Says Thank You to rocky telecom For This Useful Post:
Old 02-02-2011, 11:20   #15 (permalink)
Member: 808657
Sonork: 100.1590300
Thanks Meter: 112
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-26-1999 01:00
Page generated in 0.44342 seconds with 10 queries
