Old 12-30-2019, 11:00   #1 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
nokia 3.2 onlay fastboot mode
how to flash
and need firmware
Operation : Identify [ v1.03 ]
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
INFO : version:0.5
INFO : battery-soc-ok:yes
INFO : battery-voltage:3839409
INFO : variant:QRD eMMC
INFO : unlocked:yes
INFO : secure:yes
INFO : version-baseband:
INFO : version-bootloader:
INFO : logical-block-size:0x200
INFO : erase-block-size:0x200
INFO : display-panel:
INFO : off-mode-charge:0
INFO : charger-screen-enabled:0
INFO : max-download-size: 0x1ff00000
INFO : slot-count:2
INFO : current-slot:INVALID
INFO : slot-retry-count:b:0
INFO : slot-success:b:No
INFO : slot-active:b:No
INFO : slot-unbootable:b:Yes
INFO : slot-retry-count:a:7
INFO : slot-success:a:No
INFO : slot-active:a:No
INFO : slot-unbootable:a:No
INFO : has-slot:userdata: No
INFO : has-slot:demoapp: No
INFO : has-slot:elabel: No
INFO : has-slot:wt_log: No
INFO : has-slot:logdump: No
INFO : has-slot:dpo: No
INFO : has-slot:msadp: No
INFO : has-slot:apdp: No
INFO : has-slot:custom: Yes
INFO : has-slot:keymaster: Yes
INFO : has-slot:cmnlib64: Yes
INFO : has-slot:cmnlib: Yes
INFO : has-slot:mcfg: No
INFO : has-slot:syscfg: No
INFO : has-slot:mdtp: Yes
INFO : has-slot:dip: No
INFO : has-slot:mota: No
INFO : has-slot:limits: No
INFO : has-slotem: No
INFO : has-slot:config: No
INFO : has-slot:keystore: No
INFO : has-slot:misc: No
INFO : has-slotersist: No
INFO : has-slot:vendor: Yes
INFO : has-slot:system: Yes
INFO : has-slot:devinfo: No
INFO : has-slot:boot: Yes
INFO : has-slot:vbmeta: Yes
INFO : has-slot:dtbo: Yes
INFO : has-slot:aboot: Yes
INFO : has-sloticture: Yes
INFO : has-slot:splash: Yes
INFO : has-slot:sec: No
INFO : has-slot:fsg: No
INFO : has-slotDR: No
INFO : has-slot:modemst2: No
INFO : has-slot:modemst1: No
INFO : has-slot:dsp: Yes
INFO : has-slot:devcfg: Yes
INFO : has-slot:tz: Yes
INFO : has-slot:rpm: Yes
INFO : has-slot:sbl1: Yes
INFO : has-slot:ssd: No
INFO : has-slot:fsc: No
INFO : has-slot:modem: Yes
INFO : partition-type:userdata:ext4
INFO : partition-size:userdata: 0x187a79e00
INFO : partition-type:demoapp:raw
INFO : partition-size:demoapp: 0x4000000
INFO : partition-type:elabel:raw
INFO : partition-size:elabel: 0x500000
INFO : partition-type:wt_log:raw
INFO : partition-size:wt_log: 0x4000000
INFO : partition-type:logdump:raw
INFO : partition-size:logdump: 0x4000000
INFO : partition-type:dpo:raw
INFO : partition-size:dpo: 0x2000
INFO : partition-type:msadp:raw
INFO : partition-size:msadp: 0x40000
INFO : partition-type:apdp:raw
INFO : partition-size:apdp: 0x40000
INFO : partition-type:custom_b:raw
INFO : partition-size:custom_b: 0x3200000
INFO : partition-type:custom_a:raw
INFO : partition-size:custom_a: 0x3200000
INFO : partition-type:keymaster_b:raw
INFO : partition-size:keymaster_b: 0x100000
INFO : partition-type:keymaster_a:raw
INFO : partition-size:keymaster_a: 0x100000
INFO : partition-type:cmnlib64_b:raw
INFO : partition-size:cmnlib64_b: 0x100000
INFO : partition-type:cmnlib64_a:raw
INFO : partition-size:cmnlib64_a: 0x100000
INFO : partition-type:cmnlib_b:raw
INFO : partition-size:cmnlib_b: 0x100000
INFO : partition-type:cmnlib_a:raw
INFO : partition-size:cmnlib_a: 0x100000
INFO : partition-type:mcfg:raw
INFO : partition-size:mcfg: 0x400000
INFO : partition-type:syscfg:raw
INFO : partition-size:syscfg: 0x80000
INFO : partition-type:mdtp_b:raw
INFO : partition-size:mdtp_b: 0x2000000
INFO : partition-type:mdtp_a:raw
INFO : partition-size:mdtp_a: 0x2000000
INFO : partition-type:dip:raw
INFO : partition-size:dip: 0x100000
INFO : partition-type:mota:raw
INFO : partition-size:mota: 0x80000
INFO : partition-type:limits:raw
INFO : partition-size:limits: 0x8000
INFO : partition-typeem:raw
INFO : partition-sizeem: 0x4000000
INFO : partition-type:config:raw
INFO : partition-size:config: 0x8000
INFO : partition-type:keystore:raw
INFO : partition-size:keystore: 0x80000
INFO : partition-type:misc:raw
INFO : partition-size:misc: 0x100000
INFO : partition-typeersist:raw
INFO : partition-sizeersist: 0x2000000
INFO : partition-type:vendor_b:raw
INFO : partition-size:vendor_b: 0x28000000
INFO : partition-type:vendor_a:raw
INFO : partition-size:vendor_a: 0x28000000
INFO : partition-type:system_b:raw
INFO : partition-size:system_b: 0xc0000000
INFO : partition-type:system_a:raw
INFO : partition-size:system_a: 0xc0000000
INFO : partition-type:devinfo:raw
INFO : partition-size:devinfo: 0x100000
INFO : partition-type:boot_b:raw
INFO : partition-size:boot_b: 0x4000000
INFO : partition-type:boot_a:raw
INFO : partition-size:boot_a: 0x4000000
INFO : partition-type:vbmeta_b:raw
INFO : partition-size:vbmeta_b: 0x10000
INFO : partition-type:vbmeta_a:raw
INFO : partition-size:vbmeta_a: 0x10000
INFO : partition-type:dtbo_b:raw
INFO : partition-size:dtbo_b: 0x800000
INFO : partition-type:dtbo_a:raw
INFO : partition-size:dtbo_a: 0x800000
INFO : partition-type:aboot_b:raw
INFO : partition-size:aboot_b: 0x400000
INFO : partition-type:aboot_a:raw
INFO : partition-size:aboot_a: 0x400000
INFO : partition-typeicture_b:raw
INFO : partition-sizeicture_b: 0x600000
INFO : partition-typeicture_a:raw
INFO : partition-sizeicture_a: 0x600000
INFO : partition-type:splash_b:raw
INFO : partition-size:splash_b: 0x600000
INFO : partition-type:splash_a:raw
INFO : partition-size:splash_a: 0x600000
INFO : partition-type:sec:raw
INFO : partition-size:sec: 0x4000
INFO : partition-type:fsg:raw
INFO : partition-size:fsg: 0xa00000
INFO : partition-typeDR:raw
INFO : partition-sizeDR: 0x8000
INFO : partition-type:modemst2:raw
INFO : partition-size:modemst2: 0x400000
INFO : partition-type:modemst1:raw
INFO : partition-size:modemst1: 0x400000
INFO : partition-type:dsp_b:raw
INFO : partition-size:dsp_b: 0x1000000
INFO : partition-type:dsp_a:raw
INFO : partition-size:dsp_a: 0x1000000
INFO : partition-type:devcfg_b:raw
INFO : partition-size:devcfg_b: 0x40000
INFO : partition-type:devcfg_a:raw
INFO : partition-size:devcfg_a: 0x40000
INFO : partition-type:tz_b:raw
INFO : partition-size:tz_b: 0x200000
INFO : partition-type:tz_a:raw
INFO : partition-size:tz_a: 0x200000
INFO : partition-type:rpm_b:raw
INFO : partition-size:rpm_b: 0x80000
INFO : partition-type:rpm_a:raw
INFO : partition-size:rpm_a: 0x80000
INFO : partition-type:sbl1_b:raw
INFO : partition-size:sbl1_b: 0x80000
INFO : partition-type:sbl1_a:raw
INFO : partition-size:sbl1_a: 0x80000
INFO : partition-type:ssd:raw
INFO : partition-size:ssd: 0x2000
INFO : partition-type:fsc:raw
INFO : partition-size:fsc: 0x400
INFO : partition-type:modem_b:raw
INFO : partition-size:modem_b: 0x5400000
INFO : partition-type:modem_a:raw
INFO : partition-size:modem_a: 0x5400000
INFO : hw-revision:10000
INFO : pcb_sn:4942907491003878
INFO : serialno:4T89626AA1950810633
INFO : kernel:lk
INFO : producteadpool
INFO : productid:4T89626AA1950810633
INFO : block_factory_reset:
INFO : block_fastboot_mode:
INFO : MEID:00000000000000
INFO : IMEI1:352907101273696
INFO : IMEI0:352907101273688
INFO : proof:1
OEM : Device tampered: false
OEM : Device unlocked: true
OEM : Charger screen enabled: false
OEM : Display panel:
Done!
Elapsed: 00:00:03
Old 12-30-2019, 12:28   #2 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
Card found : A0222296 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19
Operation : Identify [FTM] [ v1.19 ]
-> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable
-> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Dev Model : Deadpool
HW version : 1
HW variant : QRD eMMC
HW RF_BAND : GSM_850_900_1800_1900^W1_5_8^L_1_3_5_7_8_20_28_38_ 40
SW version : V1.39E_B01
SW CurrSlot : INVALID
SW serialnm : 4T89623AA6951810630
SW secured : YES
Project DevCode : Deadpool
Bootloader type : WT2
Security Version : 0003
Done!
Elapsed: 00:00:07
Reconnect Power/Cable!
Page generated in 0.16501 seconds with 8 queries
