07-11-2008, 16:47 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: INDIA
Member: 566051 Status: Offline Thanks Meter: 105 | Insert Sim In china phone Both information log is hare.......... Genral information Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: CBM25_06B_HW Software version: CBM10_X710D_V22" Software date: 2006.06.14 Barcode: 00000000000000000000 imei: 000000000000000 Finished, time used: 5 sec Power off phone now ! Detail information COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:0F03:000E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.EDCFC750.[CBM6225_06B_PCB01_GPRS_MT6225_S00.CBM10_X710D_V22. BIN_6E5ED857].rpl New firmware detected: CBM6225_06B_PCB01_GPRS_MT6225_S00.CBM10_X710D_V22. BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: EDCFC750 identification#1 protocol ver: 04 ver. sw1: CBM6225_06B_PCB01_GPRS_MT6225_S00.CBM10_X710D_V22. BIN ver. sw2: CBM10_X710D_V22, A827A191 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ..................... detect standard fat location pass #1... .................................................. . detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ..................... detect standard fat location pass #1... .................................................. . detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _EDCFC750_CBM6225_06B_PCB01_GPRS_MT6225_S00.CBM10_ X710D_V22.BIN_6E5ED857_20080711-174219.B0X.bin Finished, time used: 74 sec Remove/Install battery now ! |
07-11-2008, 18:51 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If phone can not make 112 call in most cases you need to repair phone hardware. zero imei: you can try to write any reasonoble imei and check phone again but I don\'t think this may helps. |
07-11-2008, 20:14 | #6 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
12-14-2010, 07:52 | #10 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | but i have intex in 2010 nano phone model and imei is ok and genuine but when i put Sim in phone it shows insert sim ....i tried full flash with spider man and handset is OK working very well but problem is insert Sim is still any solution ???? |
12-14-2010, 10:59 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
this seems to be hardware problem | |
problem in calibrate in china phone | FullFlashPak | Infinity-Box | 3 | 07-12-2009 12:22 |
insert sim chip with phone se k550im insert sim | lyne | Old Ericsson Phones & Sony Phones | 0 | 03-16-2009 08:50 |
5200 Water Damaged Contact Service In Battery.., Insert Sim In Cable | CHAPRAN | Nokia Hardware & Hardware Repair | 3 | 09-10-2007 05:49 |
insert sim in a 02 x3? can anyone help | ashvin | Infinity-Box | 1 | 09-04-2006 21:35 |
c25 insert sim card..with sim in the phone | s4sajii | Siemens Hardware Repair Area | 4 | 04-19-2003 16:45 |
