intex 4495 imei 0000000000000 how 2 solved intex 4495 imei 0000000000000 i will try all methods but not sucess ............... infinity team it is big problem how to solved this problem |
this is my post image restore solved this eprom file but imei is same 00000000000 |
pls, post here operation logs for all imei repair methods. |
here is log module v3.26 Action: "repair imei" imei write method: mode-2 imei write channel: imei #2 for dual sim/mono CPU new imei: 910001493763251 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6C03:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: INTEX_IN4495_Z808_Z808_L404_5M4 Version: DEWAV25_07B_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 00000000000000 connection Ok detecting structure #2... 5 11 done 67 byte(s) read verification... verification done: 91000149376325 Finished, time used: 14 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: DEWAV25_07B_GEMINI_HW Software version: INTEX_IN4495_Z808_Z8 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 910001493763251 imei-2: 000000000000000 imei-3: 910001493763251 Finished, time used: 7 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: DEWAV25_07B_GEMINI_HW Software version: INTEX_IN4495_Z808_Z8 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 000000000000000 imei-2: 000000000000000 imei-3: 000000000000000 Finished, time used: 5 sec Remove/Install battery now ! |
try to "default imei inside firmware" COM6 [VCP1] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 910001493712258 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6C03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: DEWAV25_07B_GEMINI_Z868_PCB01_GPRS_MT6225_S00.INTE X_IN4495_Z808_Z808_L404_5M4.BIN project-id: INTEX_IN4495_Z808_Z808_L404_5M4, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ............................ ffs/eeprom: detect std location pass #1... .................................................. . ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 13579024681122 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFF0043:2088C400000000 Finalization Done Finished, time used: 2 min 57 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: DEWAV25_07B_GEMINI_HW Software version: INTEX_IN4495_Z808_Z8 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 000000000000000 imei-2: 000000000000000 imei-3: 000000000000000 Finished, time used: 14 sec Remove/Install battery now ! Imei 91000149371225 already was repaired: 3/15/2011-11:26:52 AM Continue with this imei ? Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 000000000000000 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 910001493712258 verification Ok Finished, time used: 3 sec Remove/Install battery now ! Imei 91000149371225 already was repaired: 3/15/2011-11:29:41 AM Continue with this imei ? Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 910001493712258 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 910001493712258 verification Ok Finished, time used: 7 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: DEWAV25_07B_GEMINI_HW Software version: INTEX_IN4495_Z808_Z8 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 000000000000000 imei-2: 000000000000000 imei-3: 000000000000000 Finished, time used: 3 sec Remove/Install battery now ! Imei 91000149371225 already was repaired: 3/15/2011-11:30:12 AM Continue with this imei ? ==== [3/15/2011 11:30:32 AM] ==== COM6 [VCP1] selected module v3.27 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 910001493712258 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6C03:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: INTEX_IN4495_Z808_Z808_L404_5M4 Version: DEWAV25_07B_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 00000000000000 connection Ok detecting structure #2... 5 11 done 67 byte(s) read verification... verification done: 91000149371225 Finished, time used: 20 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: DEWAV25_07B_GEMINI_HW Software version: INTEX_IN4495_Z808_Z8 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 910001493712258 imei-2: 000000000000000 imei-3: 910001493712258 Finished, time used: 3 sec Remove/Install battery now ! Imei 91000149371225 already was repaired: 3/15/2011-11:30:59 AM Continue with this imei ? ==== [3/15/2011 11:31:41 AM] ==== COM6 [VCP1] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono CPU new imei: 910001493712258 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6C03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: DEWAV25_07B_GEMINI_Z868_PCB01_GPRS_MT6225_S00.INTE X_IN4495_Z808_Z808_L404_5M4.BIN project-id: INTEX_IN4495_Z808_Z808_L404_5M4, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: DEWAV25_07B_GEMINI_Z868_PCB01_GPRS_MT6225_S00.INTE X_IN4495_Z808_Z808_L404_5M4__ffs... file saved: C:\InfinityBox\ChineseMiracle\DEWAV25_07B_GEMINI_Z 868_PCB01_GPRS_MT6225_S00.INTEX_IN4495_Z808_Z808_L 404_5M4__ffs_20110315-113707.B0E.bin flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... 30 step(s) required Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 2088C4FFFF0043:2088C400000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 4 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: DEWAV25_07B_GEMINI_HW Software version: INTEX_IN4495_Z808_Z8 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 000000000000000 imei-2: 000000000000000 imei-3: 000000000000000 Finished, time used: 4 sec Remove/Install battery now |
infinity team confuse ho gaye kya................................ |
u need read file from good working set and write on faulty on .this may help you |
plz post good read flash file........................................ |
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@2 |
koi tuh help karo.............................................. ....... |
are yaar mujhe bhi iski file chahiye kisi ke paas he kya? i am also looking for file. someone pls upload the flash file for it my imei is 00000000000000 |
Bro no solution with infinity with In-4495 see here...... http://forum.gsmhosting.com/vbb/7201811-post16.html |
@jagritisharma What was happened with phone that imei become zero? What is this phone history ? |
