Old 11-28-2016, 13:20   #1 (permalink)
Member: 2329547
Thanks Meter: 15
Thumbs up to our dear infinity coder
hello coder,
pls add reset in SVC mode for spd6820/8810 chips.
i know this is not that hard for you to do, so pls consider this request. thanks.
selected from soft sc6815 emmc generic
Operation : Format File System / Reset Settings [ v1.23 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
==== Wait for phone...
Phone found! [ 95 ]
Port Opened
Sync...
Normal Mode init
Sync...
Init Ok , reset settings ...
Format Error!
Done
Elapsed: 00:00:30
Reconnect Power/Cable!
Old 11-28-2016, 14:05   #2 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Originally Posted by pasc View Post
hello coder,
2. Insert cable
Phone found! [ 95 ]
Port Opened
Sync...
Normal Mode init
Sync...
Format Error!
Done
Elapsed: 00:00:30
It's already Exit
If SVC mode ReadInfo Supported, then format option will be working too
Try your self & post result here.
Old 11-28-2016, 16:10   #3 (permalink)
Member: 2329547
Thanks Meter: 15
Originally Posted by mbiborna View Post
It's already Exit
well, i guess this phone has nand cpu. i just selected emmc 6815 to see what would happen. i think if coder is interested this chips can be supported. still waiting coder's reply on this. wbr,
The Following User Says Thank You to pasc For This Useful Post:
Old 11-28-2016, 23:48   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello pasc,
thank you for your suggestion
I will check your log text and your request carefullly.
Page generated in 0.13995 seconds with 8 queries
