Invens H1 hang on logo cannot be flashed when PMT is selected onCM2 SP2 2.7 Dear i manage to copy flash file of invens H 1, when trying to flash this flash file on Phone which hang on log , CM2SP2 can not flash the phone Operation : Flash Firmware [ v2.07 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update failed! ERROR : 00000084:84000000FF7B7E00 SYS : OPERATION FAILED! Error : Flashing failed! Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process Reconnect Power/Cable! when i unselect PMT update; the soft flash the phone till end but phone always hang on logo Operation : Flash Firmware [ v2.07 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : False 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! FSIMG : prodnv.img CODE : wmodem.bin CODE : wdsp.bin CODE : modem_wcn.img CODE : boot_logo.bmp CODE : fastboot_logo.bmp CODE : logo2.bin CODE : logo3.bin CODE : logo4.bin CODE : logo5.bin CODE : boot.img FSIMG : system.img FSIMG : persist.img FSIMG : sysinfo.bin FSIMG : cache.img CODE : recovery.img FSIMG : userdata.img UBOOT : u-boot.bin UBOOT : u-boot-spl.bin ERASE : WFLASH ERASE : WCNFLASH ERASE : MISC Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:04:25 https://ibb.co/dPqf4Y1 https://ibb.co/RbHnRzs so please i need some suggestion leroi |
In most case that error represent eMMC fault. Try following : Select BASE loader to boot device, remember which one used ( try first all SS, then RS ) After select FW, then go to platform tab back and select base, which had work for that phone. Repeat flashing with PMT update. What a result? |
