03-28-2021, 12:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 381846 Status: Offline Sonork: 123.786786 Thanks Meter: 54 | every andriod mobile identyfi faild 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : AFADFC57BE2CA2E4653BCBA1C4AF9750 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Enabled BROM : SOCID : F9EB5A67013808DA74B30BEFDFEF398EA9002FF52EDE54B343 E7D787D6B44C80 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AL~1.BIN AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! MRD-LX1F |
03-28-2021, 16:09 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Read error message carefully. If you can't find correct DA/auth for particular phone then best way is to do it with sSLA option in BROM mode with latest Base. Br. Infinity-Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-23-2021, 06:53 | #4 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | LEAGOO M9PRO da file need please.... -------------------- PTFN : MediaTek USB Port_V1633 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : 443DD323DC2468A6C45A907267A32CE6 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4972B6747F993DD44D33D2136B4C5182E8A31F656486694B73 0E55888FFE7A01 BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_pu562_lg_l5705l.bin EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
09-23-2021, 08:20 | #5 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Try with sSLA option checked | |
