04-23-2010, 10:29 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Kosova
Member: 87568 Status: Offline Thanks Meter: 101 | iPhone 32gb chinesse iPhone32GB This phone has same as original iPhone pinout but i solder vires in back of board because with pinfinder this cable is missing. Please can someone tell me about iPhone32g, did is supported by infinty box? |
04-23-2010, 12:11 | #2 (permalink) | |
What is this phone CPU chip name ? If it's like MT62xx - this means that this model is supported. Did you tried to detect pinout with PinFinder ? If pinout can be detected - post here detection log so we will check it. | |
04-23-2010, 14:24 | #3 (permalink) |
Member: 87568 Status: Offline Thanks Meter: 101 | CPU name is MT6225 , i try to full reset but not repaired, this is llog: COM6 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1103:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F29AF8FA.[HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN_6FCC20DB].rpl rom info detection finished ==================== New firmware detected (v.3.07, database date: unknown): HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: F29AF8FA rom info ver: 05 sw version: HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN project-id: ONECOM_V188, DB20CC6F code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188_ _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\HR25_08A_GEMINI_P CB01_GPRS_MT6225_S00.ONECOM_V188__ffs_20100423-151629.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H R25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188__ system_log_F29AF8FA_6FCC20DB_20100423-151719.B0X.bin Finished, time used: 5 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-24-2010, 07:49 | #5 (permalink) |
Member: 87568 Status: Offline Thanks Meter: 101 | Problem is this: When turn on phone just show apple and turn off. Nothing more. When try to power on again , can`t power while not remove battery and atach again. Battery is full . |
04-24-2010, 08:02 | #6 (permalink) | |
Freak Poster Join Date: Sep 2004 Location: indonesia Age: 47
Member: 82846 Status: Offline Thanks Meter: 29 | Quote:
Same problem... ==== [24/04/2010 13:32:10] ==== COM9 [VCP0] selected module v3.12 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E603:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.54EFB411.[HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN_384BE336].rpl rom info detection finished ==================== New firmware detected (v.3.12, database date: unknown): HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 54EFB411 rom info ver: 05 sw version: HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN project-id: ONECOM_V188, 36E34B38 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_54EFB411_384BE336_20100424-133415.B0X.bin Finished, time used: 1 min 44 sec Remove/Install battery now ! anyone can hepl this problem? Br, | |
04-24-2010, 09:04 | #8 (permalink) | |
COM9 [VCP0] selected module v3.12 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188_ _ffs_20100410-142212.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E603:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.54EFB411.[HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN_384BE336].rpl rom info detection finished ==================== New firmware detected (v.3.12, database date: unknown): HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 54EFB411 rom info ver: 05 sw version: HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188. BIN project-id: ONECOM_V188, 36E34B38 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H R25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188__ system_log_54EFB411_384BE336_20100424-145226.B0X.bin Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H R25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188__ system_log_54EFB411_384BE336_20100424-145349.B0X.bin Finished, time used: 2 min 2 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [24/04/2010 14:54:13] ==== COM9 [VCP0] selected module v3.12 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E603:0003 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: ONECOM_V188 Version: 08AW0840_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35301209929612 connection Ok building list... done items total: 155 items to clear: 155 warning: wrong packet cs warning: wrong packet cs items cleared: 155 of 155 building list... done items remains: 0 Finished, time used: 40 sec not work, only logo and off... br, Ps. already flash with 4 file in support, still same problem. | |
repair nec e616 in chinesse language | peo | NEC | 5 | 09-03-2006 13:21 |
@Adan[iphone] | zeeber | The Market Feed Back | 8 | 08-03-2005 20:22 |
v60 and only chinesse... Heeeelllppp... Please... | Dream gsm | Motorola P2k | 4 | 04-05-2005 23:28 |
winswup sl55 with chinesse | japunlock | Siemens-Benq RingTones and WallPapers | 1 | 02-14-2005 12:19 |
6150 v5.17 only chiness language!!! | hiall | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-26-2001 21:49 |
