03-27-2009, 21:55 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
03-28-2009, 12:46 | #11 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: here :) Age: 41
Member: 176010 Status: Offline Thanks Meter: 12 | Quote:
for step (4) "battery attached,,, should while measure pins, phone be on ?? or just attach battery only without powering it on" ??? thanks for ur useful info. | |
HELP how to unlock iphone 3.1 | laksh007 | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 03-31-2010 03:22 |
iphone unlock help for bigners | Mind Power | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 03-29-2010 17:05 |
iPhone 3G Accessories by iLLuminatik ..... iPhone 3G.. iPhone 3G.. iPhone 3G.. | miliky | Main Sales Section | 0 | 08-15-2008 10:35 |
