Old 03-03-2011, 17:53   #1 (permalink)
electrolandgsm's Avatar
Member: 174315
Thanks Meter: 123
Iphone 911 dual sim help
hi
i try to format ffs , but i get error:
COM3 [VCP1] selected
module v3.13
Device: Autodetect 6228-6229 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:0003
status: FF
boot packet size: 0400
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 17 sec
Remove/Install battery now !
i tried via pinfinder , and i also soldered wires...but no succes.
could this be the problem ?
new cpu mtk..: CPU: MT6235
waiting for any suggestions
Old 03-04-2011, 03:27   #2 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 505
try to select other cpu tipe.6228-6253 nand. and post resalt..
Old 03-04-2011, 09:08   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
What is the problem with the phone?
Use latest chinese miracle 3.27 and try again.
Wr.
Old 03-04-2011, 09:54   #4 (permalink)
Member: 174315
Thanks Meter: 123
already tried diferent settings/platforms , but no connection.
phone needs a reset, to factory reset, because customer want to sell this phone.
is not hardware related, phone is working fine
Old 03-04-2011, 10:53   #5 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Try with "6235 Nor" option with latest Chinese Miracle3.27.
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-04-2011, 11:21   #6 (permalink)
Member: 174315
Thanks Meter: 123
booting problem was solved thx to PASSIONATE_BOYS
now i have this:
module v3.27
Device: Autodetect 6253 NOR
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0006]: 00EC:00A100000015 [SAMSUNG] K9F1G08Q0M
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02620000/059E0000
firmware size: 38Mb
ffs size: 89Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: M800_MST_IP_MLD_18V_T06S0528
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M800_MST_IP_M LD_18V_T06S052
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M800_MST_IP_ML D_18V_T06S0528.BIN
project-id: M800_MST_IP_MLD_18V_T06S0528, 00000000
code offset: 00000000
ffs offset/size [01]: 02620000/059E0000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.27, database date: 01.03.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
warning: can not format: HW_STORAGE_NOR is not present
Format...
Disconnect...
done
Finished, time used: 3 min 32 sec
Old 03-04-2011, 11:57   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
now i have this:
module v3.27
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
done
done
ram test...
testing...
ram test passed
detect ffs...
firmware size: 38Mb
ffs size: 89Mb
detect sec ro...
detect NAND info...
TCL-ID detection...
rom info ver: 07
TCL-ID is absent
===> done
Format...
Disconnect...
done
Hello,
Now select "6228-6253 NAND" and format the set.
Also if set is working fine then read full flash and send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
Please do not send flash if set is not working properly.
You can see above highlighted line and can understand why I tell you to select 6228-6253 NAND option now.
Wr.
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-04-2011, 13:11   #8 (permalink)
Member: 174315
Thanks Meter: 123
module v3.27
Device: Autodetect 6228-6253 NAND
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
done
Set baudrate (230400)...
done
ram test...
testing...
ram test passed
detect ffs...
firmware size: 38Mb
ffs size: 89Mb
detect sec ro...
detect NAND info...
TCL-ID detection...
rom info ver: 07
TCL-ID is absent
===> done
Format...
Disconnect...
done
Finished, time used: 2 min 16 sec
here is link with backup and txt file with logs
http://rapidshare.com/files/450899735/New_Folder.rar
The Following User Says Thank You to electrolandgsm For This Useful Post:
Old 03-04-2011, 22:24   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
module v3.27
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
done
done
ram test...
testing...
ram test passed
detect ffs...
firmware size: 38Mb
ffs size: 89Mb
detect sec ro...
detect NAND info...
TCL-ID detection...
rom info ver: 07
TCL-ID is absent
===> done
Format...
Disconnect...
done
Hello,
Thank you very much !
We will check, prepare and upload files in support area as soon as possible.
Old 03-06-2011, 23:04   #10 (permalink)
Member: 130995
Format...
Disconnect...
done
As I can see phone was formatted well. NOR flash is not present and it was not formatted, but NAND flash was detected and format was done.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.20942 seconds with 9 queries
