Old 11-14-2008, 06:39   #1 (permalink)
UnLoCkit's Avatar
Member: 486305
Thanks Meter: 465
Iphone A9 Dead Done by Infinity!![ With PINOUT"S]
Problem;
Dead
Procedure;
-Open Infinity Shell/select Brand [Chinese-Miracle]/ Model [Other-China-clone-model]/ Click run
-Select com/Select Complete/click format ffs/power on the phone
Pinout's;
Formating;
Log's
COM6 [VCP0] selected
module v2.68
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:E503:000C
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: F490_M08-CN3-HW_V1_1-SW_V005.BIN
ver. sw 2: F490_M08-CN3-HW_V1.1-SW_V005, 00000000
ffs offset/size: 00E00000/001F0000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[F490_M08-CN3-HW_V1_1-SW_V005.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[F490_M08-CN3-HW_V1_1-SW_V005.BIN]_20081114-104234.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
write ...
write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 188 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Change Imei;
Log's
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E03
Hardware version: F490_M08_V1.1
Software version: F490_M08-CN3-HW_V1.1
Software date: 2006.06.14
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei: 354236020096501
verification Ok
Finished, time used: 6 sec
Power off phone now !
Viola;
RG;
TSMABKOL TEAM
The Following 5 Users Say Thank You to UnLoCkit For This Useful Post:
Old 11-14-2008, 20:38   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
3110c dead done by USB flashing Mintsea Universalbox 1 03-29-2010 11:54
Iphone Q380A+ dead Done by Infinity[Pinout's Inside] UnLoCkit Infinity-Box 2 09-06-2009 11:14
Mp4 Mini China Phone Dead Done by Infinity!! UnLoCkit Infinity-Box 2 10-09-2008 22:23
POCKET PDA (F1) China Phone Dead Done By Infinity!! UnLoCkit Infinity-Box 3 10-09-2008 22:08
N77 mini china phone dead done by Infinity UnLoCkit Infinity-Box 3 08-05-2008 23:34
Page generated in 0.18673 seconds with 9 queries
