05-19-2009, 13:42 | #1 (permalink) |
Junior Member Join Date: May 2006 Location: phillipines
Member: 273001 Status: Offline Thanks Meter: 3 | Iphone mini need firmware Thanks in Advance.......... |
The Following User Says Thank You to charlz_009 For This Useful Post: |
05-19-2009, 21:40 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! noone can advice you correct flash file without knowing your phone software version. for this you must make "read detailed information" operation and post log here. we will advice same or similar flash file. however you can do this yourself using this easy tutorial: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
05-20-2009, 06:42 | #3 (permalink) | |
Member: 273001 Status: Offline Thanks Meter: 3 | i tried to flash with other firmware with infinity Quote:
05-20-2009, 17:08 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! use this flash file: flashfiles/ChineseMiracle/_MT6205-MT6227/M531G_MULTILANG_HW2.0V21_081013__iPhone-mini_16m_En_Ru_Fr_Es_Th_Ar.B0M.bin i am not 100% sure that it will work in your phone, but as long as it is already damaged by wrong flashing- worth to try post result here |
05-21-2009, 07:48 | #6 (permalink) | |
Member: 273001 Status: Offline Thanks Meter: 3 | Quote:
thank you sir.... Problem Solve............... | |
05-25-2009, 21:45 | #10 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
you can test this pins by yourself. just measure voltage on system connector pins pins with voltage 2,7-2,9 volts will be Tx/Rx phone battery must be attached, of course. | |
05-26-2009, 21:52 | #11 (permalink) |
Junior Member Join Date: May 2009
Member: 1037543 Status: Offline Thanks Meter: 1 | hello again ) I find code - *#20080808# And I find number pins: 5 - gnd 6 - Tx 7 -Rx Had firmware M531G_MULTILANG_HW2.0V21_081013__iPhone-mini_16m_En_Ru_Fr_Es_Th_Ar.B0M.bin Java or not? |
03-10-2010, 03:01 | #12 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1255696 Status: Offline Thanks Meter: 0 | espero que aqui exista alguien que hable espaņol, tengo un tlf igual a ese en la caja dice oggo n98 pero no se como ver la firmware aparte de eso como hago para cambiar el firmware sin cables especiales preferiblemente.. ayuda por favor mi tlefono solo trae 12 menus de los cuales dos son para enviar msjs no puedo cambiar los tonos al los msjs ni entrar en el menu del bluethoot ni mucho menos ver tv ni radio ni internet para eso es mejor mi gtran que tenia antes... saludos espero me puedan ayudar pleaseeeeee |
need firmware | ajit bs | Infinity-Box | 1 | 03-30-2010 05:05 |
iphone 16G A1241 firmware need | oxbridge | Chinese Models & Cloned Phones | 1 | 01-13-2010 21:19 |
Need firmware 3.0 for 3GS Iphone........ | dodzkie | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 08-03-2009 07:19 |
need-help regarding iphone mini m88a (china phone) | vindy2345 | Chinese Models & Cloned Phones | 0 | 06-30-2009 08:01 |
restore firmware in iphone fail,need help | solution4mobile | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 11-17-2007 05:56 |
