GSMSERVER GSM Shop
Old 09-22-2016, 07:48   #1 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 79
Itel it 1407 5.1 read info, read flash done at long last
Start  at : [9/22/2016 / 6:15:13 AM]
Operation : Check/Read Info [ v1.22 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 40 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : c219_tsl_121
Model Brand : itel
Model Device: c219_tsl_121
AndrVersion : 5.1
BaseBand CPU: C219_TSL_121
CompileDate : 6/3/2016 1:30:56 PM
Project Ver : LMY47D release-keys
Model Ext   : itel it1407
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:21
The Following User Says Thank You to papinto For This Useful Post:
Old 09-22-2016, 07:52   #2 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 79
READ FLASH
Start  at : [9/22/2016 / 6:16:18 AM]
Operation : Read FullFlash [ v1.22 ]
3. Insert cable
Phone found! [ 40 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 40 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 40 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : itel
AndrVersion : 5.1
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731g_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x800.bin
[Read Ok] : fblogo_480x800.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : oem.bin
[Read Ok] : sysinfo.bin
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1928 MiB
Saved to : C:\InfinityBox\CM2SPD\Flash\C219_TSL_121_c219_tsl_121_5.1_LMY47D_release-keys_itel_it1407\
Done!
Elapsed: 00:16:37
The Following 3 Users Say Thank You to papinto For This Useful Post:
Old 10-02-2016, 20:38   #3 (permalink)
Ouzigzag's Avatar
Member: 1753151
Sonork: 100.1658597
Thanks Meter: 326
Thanks for the test report.
Did you test it with itel 1407 android 5 ?
The Following User Says Thank You to Ouzigzag For This Useful Post:
Old 10-02-2016, 22:34   #4 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 79
YES
ANDROID VERSION: 5.1
CPU: SC7731c
U CAN CHECK IT IN MY LOGS
Old 10-11-2016, 11:07   #5 (permalink)
fum
Member: 2263030
Sonork: 100.1659104
Thanks Meter: 23
Originally Posted by papinto View Post
YES
CPU: SC7731c
any special procedure for resd flash this ic
The Following User Says Thank You to fum For This Useful Post:
Old 10-11-2016, 11:31   #6 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 79
I HAD BOOT FAILED AS YOURS IN WINDOWS 7 SO I TRIED IT ON WINDOWS XP SP3 AND IT WORKED...NOTHING ELSE
I USED SC7731 Android 6 / CRev AS MY BOOT (WITHOUT ALTLDR)
TRY IT AND REPORT RESULT HERE
BEST OF LUCK
The Following 2 Users Say Thank You to papinto For This Useful Post:
Old 10-11-2016, 11:40   #7 (permalink)
.::MAHABUB::.'s Avatar
Member: 939797
Sonork: 100.1601089
Thanks Meter: 352
sir jaydi
please look this problem and solve it.i have this phone and not booting at win7.
The Following 2 Users Say Thank You to .::MAHABUB::. For This Useful Post:
Old 10-11-2016, 12:16   #8 (permalink)
fum
Member: 2263030
Sonork: 100.1659104
Thanks Meter: 23
BEST OF LUCK
sir i tried on xp sp3 and win 7 also
Old 10-22-2016, 03:58   #9 (permalink)
Member: 1671566
Sonork: 100.1645138
Thanks Meter: 21
ITEL iT1508 PLUS READ FAILED....
3. Insert cable
Phone found! [ 6 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Reconnect Power/Cable!
The Following User Says Thank You to Roshan Chauhan For This Useful Post:
Old 10-22-2016, 04:00   #10 (permalink)
Member: 1671566
Sonork: 100.1645138
Thanks Meter: 21
LYF FLAME 7 (LS-4006) ALSO READ FAILED...
Card found: S/N : CB279470 , v0134
Chinese Miracle II [SPD module] v 1.22
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Initial Boot Failed!
3. Insert cable
Phone found! [ 6 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Device boot not done
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Phone found! [ 6 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
I TRIED EVERYTHING ....BUT STILL SAME......
Old 10-22-2016, 04:02   #11 (permalink)
Member: 1671566
Sonork: 100.1645138
Thanks Meter: 21
Dear team please fix this issue as soon as possible
Old 10-22-2016, 10:16   #12 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,372
Post phone details,so that Team understands what,which to Fix.
The Following User Says Thank You to Kirumira For This Useful Post:
Page generated in 0.35165 seconds with 7 queries
