Old 05-08-2015, 10:30   #1 (permalink)
farshid-jan's Avatar
Member: 306118
Thanks Meter: 192
How to Fix this ERROR: Probably - "Secure Boot" or "BootLoader Locked" phone
Infinity box supprters
pls help me
how to fix this error on any operation on Huawei G610-U20 & several other models
***** by SP AUTO on SETTING
Operation : Check / Read Info [ v1.19 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
Error : DA init Failed! Error code : 0x3
Boot Error!
Operation Failed
Elapsed: 00:00:20
Reconnect Power/Cable!
**** by SP SELECT MODEL (Huawei Secured G610-Y330)
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
Will use Secure DA for boot target
DA Stat : v3.2 on BBID : 0x86
DA Sent. Configure setting now ...
DA start Failed!
Check battery , cable , drivers and try try again
how to fix this errors???
Old 05-08-2015, 10:48   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Unlock bootloader ( if it non - secured ) or wait, when I find such sample.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-08-2015, 11:08   #3 (permalink)
Member: 306118
Thanks Meter: 192
thanks for reply
i have many of this model here
this is big problem for me
Old 05-08-2015, 18:20   #4 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
you can't read factory firmware w/o unlock bootloader
The Following 2 Users Say Thank You to maanarman For This Useful Post:
Old 05-09-2015, 00:42   #5 (permalink)
Member: 389266
Thanks Meter: 17
I have the same problem
thanks for the help
Huawey G610-u15
Page generated in 0.12506 seconds with 8 queries
