09-05-2011, 13:14 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Croatia,Varazdin
Member: 33901 Status: Offline Thanks Meter: 5 | myphone 1070 unlock error COM3 [VCP0] selected module v4.01 Action: read unlock codes unlock method: read codes Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9770:000C status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 35 sec Remove/Install battery now ! |
09-06-2011, 09:26 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Yes, you are right, I was wrong. What to do if you need to manage user code: - press and HOLD phone "Power" button for a long time during boot process If it's an operator locked phone, please, read full flash and send backup file (or link) to [email protected] |
09-07-2011, 15:14 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, New file uploaded in support area: MyPhone-1070_GPLUS23P_07B_PCB01_GPRS_MT6223P_S00.S800_CROA TIA_V004_2011-01-19_En_Hr_Pl_Tele2-Croatia_v2.B0M.bin Please, try to flash phone with this file. What is the results ? |
01-11-2018, 12:01 | #6 (permalink) |
Freak Poster Join Date: Jul 2008 Location: BiH
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | MModule V4.48 Myphone 1070 after sucess sp unlocking need pin code sim card and mesage insert sim card ..How to solve Code: COM23 [VCP0] selected module v4.48 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8FE1:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done 115200 Set baud Done Initialize bootcode Done device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... ..usb bootloader detect (phase #2)... ..usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: GPLUS23P_07B_PCB01_GPRS_MT6223P_S00.S800_CROATIA_V004.BIN project-id: S800_CROATIA_V004, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................startup code area #2 is absent detecting ffs/eeprom structure pass 1... ............ffs/eeprom: detect std location pass #1... ........................................................ffs/eeprom: detect ext location pass #1... .................ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... .search sec info#1 finished Check firmware integrity Done Check firmware content Done flash: EC257E25082501:29EA0000000000 Backup required data Done .................lock area found Patch required data Done Special operation Done flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-1 Write Done Finalization Done Finished, time used: 2 min 0 sec Remove/Install battery now ! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
