01-25-2018, 14:38 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: boghé-mauritania Age: 48
Member: 106412 Status: Offline Thanks Meter: 15 | Itel a12 flashing problem ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 62 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x19 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... [FlashProc] : Error with code 0x027E00A20000FF5D7E Elapsed: 00:00:47 Reconnect Power/Cable! what is the solution B.R |
01-25-2018, 16:16 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, What is problem with the phone? Make sure you are flashing correct variant firmware. And make FlashIC Test. Br. Infinity Box Team. |
01-26-2018, 01:46 | #3 (permalink) |
Member: 106412 Status: Offline Thanks Meter: 15 | hello here tested ic and HW: Card found: S/N : 22DE5804 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 63 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Error on Flow Init! Battery/Connection problem? Test NOT PASSED! FlashIc is DAMAGED/BAD! Elapsed: 00:01:03 Reconnect Power/Cable! Operation : HW Info OP [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 63 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! HWInfo not exists, operations useless! Elapsed: 00:00:26 Reconnect Power/Cable! the customer said that he only do factory reset and the phone become hanging on logo. |
01-26-2018, 02:18 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That very likely seems as eMMC RO state. try repeat operation with other loader version ( if some other can boot it ) If result will be same - then it HW. |
